SSpoon9Marc HNew Member Introduct...Hello from VA
SSpoon9ZammyNew Member Introduct...Hello from VA
SSpoon9Uncle FesterNew Member Introduct...Hello from VA
SSpoon9rhino 2New Member Introduct...Hello from VA
SSpoon9trike ladyNew Member Introduct...Hello from VA
SSpoon9SullyNew Member Introduct...Hello from VA
SSpoon9Jack KlarichNew Member Introduct...Hello from VA
SSpoon9GorillaNew Member Introduct...Hello from VA
SSpoon9SSpoonNew Member Introduct...Hello from VA
Likes Likes:  10
Thanks Thanks:  1
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 35
Thread: Motor Trike not reputable IMO
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Default Motor Trike not reputable IMO
    Long story short: Only after 8,000 miles (of my 50,000 mile warranty), my tech. ( who installed the kit), says I have to replace the chain, front and rear sprockets, AND, he called Motor Trike who said it was wear parts AND THEY WOULD NOT REPLACE UNDER WARRANTY ! REALLY ! Only after 8,000 miles....I learned a very expensive lesson, that I may turn over to my attorney.
    50+ Posts sgmdudley's Avatar
    Apr 2011
    Longmont, Colorado
    I am confused (what else is new). I have a 2017 GL1800 w/MT Adventure kit. It does not have a chain and/or sprockets. Is it a different motorcycle?
    Robert Dudley
    Longmont, Colorado
    2017 Lvl3/Motortrike
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Yes, this is a Honda SilverWing...automatic belt driven..MT came out with a kit for it a few years ago that uses a chain drive from belt hook up
    Dec 2014
    Grand Junction, Co. USA
    Most motorcycle Manufacturers don't warantee chains and sprockets ... like clutch pads, brake pads and just about everything that is affected by how people ride (not saying you ride hard ... just the industry standard).
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    WOW, only 8K miles and chain and sprockets need replacing
    I guess I would be a bit torqued over that
  6. #6
    2250+ Posts radismukes's Avatar
    May 2018
    Angleton, Texas
    Sorry to hear about your chain problems. Chains have always been a wear and tear item on motorcycle. Roller chains need adjusting often and lubrication. If they aren't properly adjusted they will wear sprockets and chain quickly.
    I would look at the Tech who installed you kit. They would be the one who should verify the proper tension was set. But in the end the rider should check chain tension regularly.
    “Come and Take It!” “Remember the Alamo!” “Remember Goliad!”
  7. #7
    150+ Posts
    Jun 2017
    Asheville,NC USA
    I DID check chain and cleaned and lubed every third fill up. I just had my trike on last week for front tire and brakes, air filter and plugs. Chain looked at, all ( Supposedly) was ok !
  8. #8
    Meme Master
    Jan 2014
    Farmington, NH USA
    Sorry to hear of your premature chain/sprockets wear Pastor. There is no real # of miles a chain/sprocket set will run before replacement is needed, as there are too many factors that can contribute to early wear. Something caused your set to wear faster than normal. That "something" could be difficult if not impossible to determine at this point, however.
    As said above already, these are considered "wear" items by 99.9% of manufacturers.
    If they indeed need replacement, you'll have to bite the bullet and replace them.
    If it were me in your situation I'd now look at a good/quality chain maker, (Diamond, or Tsubaki comes to mind), and spring for their top of the line o-ring chain. Going cheap will get you by for awhile, but for long term happiness, quality overrides economy when it comes to chain life in my opinion.
    Additionally, correct installation/alignment/chain tension are three critical components that must all be right in order to get max life from the new chain/sprockets you need.
    Some o-ring chains require very little lubrication but cannot be run dry or failure could occur, perhaps prematurely, again.
    Good luck going forward but I wouldn't waste my $$ on attorney fees for this issue, if I were you...
    Isn't it weird that in AMERICA, our flag and our culture offend so many people...but our benefits don't???
  9. #9
    150+ Posts
    Jun 2017
    Asheville,NC USA
    I understand about the possible wear issues, however, to install this kit Motor Trike only allows those who have been through their training course to install. I used a Honda dealer who puts trikes together everyday. I was just in their shop last week and have in the past asked them to check chain....what else can I do short of driving to Shelby to another dealer?
  10. #10
    350+ Posts Downtown Cowtown's Avatar
    Aug 2015
    ft worth
    your tech set the chains too tight
  11. #11
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    point of forum rules. manufacturing bashing in not allowed. please keep it to stating a problem and getting help to resolve.
  12. #12
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Pastor Ron View Post
    yrs ago had a gs 750 and the chain was pretty well gone at 16k replaced it with a non oring chain all they had .. i was in omaha in the middle of an 8k mile trip,,, and at 4k it was worse than the original
    point is there is a big difference in chain..
    when u get your new chain i would check the alignment side to side an twist as well at the tension... if there was a little mismatch some where along the way chain would wear quicker
  13. #13
    150+ Posts
    Jun 2017
    Asheville,NC USA
    Quote Originally Posted by stacebg View Post
    I will do just that, Thank you.
  14. #14
    150+ Posts
    Jun 2017
    Asheville,NC USA
    I was just in contact with Motor Trike receptionist (who I called yesterday for info), the reply she received from their Tech. 8,000 miles is a NORMAL WEAR ISSUE ! Wow, I hate to let the trike go, but, with this as a reoccurring issue every 8,000 miles. Trike will be for sale ASAP
  15. #15
    150+ Posts
    Jun 2017
    Asheville,NC USA
    I received info from another forum site, that a Burgman 650 owner had the exact same problem at 8,000 miles, and SHE NEVER used kerosene on her chain!
  16. #16
    May 2018
    Angleton, Texas
    Ron check out this youtube link.
  17. #17
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Thats how i always cleaned chains, [Kerosene]......I even use it to unbind chain saw blades......And it is important to lube any medal that was cleaned with kerosene or it will immediately rust.....
    2019 Tri-Glide.......
  18. #18
    Jun 2008
    Lovington, NM, U.S.A.
    By chance are the sprockets made out of aluminum instead of steel?
    Retired trike builder
  19. #19
    150+ Posts
    Jun 2017
    Asheville,NC USA
    That is EXACTLY how and When I cleaned my chain. This problem (turns out) is a manufacturer flaw that occurs( most likely) every 8,000miles.
  20. #20
    Meme Master
    Jan 2014
    Farmington, NH USA
    Quote Originally Posted by trike lady View Post
    ^...Now that would cause premature wear for sure!
    I hope his answer is no..
  1. Replies: 12
    Last Post: 04-16-2019, 01:56 PM
  2. Vtx1300 Motor Trike not level
    By True1shot in forum Honda Trikes
    Last Post: 01-28-2014, 06:20 PM
  3. Replies: 4
    Last Post: 03-01-2013, 01:18 PM
  4. Replies: 0
    Last Post: 02-28-2013, 07:32 PM
  5. GW and Motor Trike raked neck or not??
    By JaysGone in forum Motor Trike
    Last Post: 11-23-2012, 10:05 AM
