xj 750 trike conversion
Jun 6, 2012
56
12
united kingdom
Hi to every one i have not been hear for a few years last time i was hear i did an how to on an xv 1100 well after just recovering from an opperation for lung cancer i need to focus on somthing else when in recovery i bought an xj 750 and now its time to trike it it will not be an how to this time i will just get on with it im not sure how to post pictures any more so will have a go and show some of the trikes i have converted since i was hear last
I am going to start with the frame of the bike and have repainted it in red and not the original black I have also cleaned and re painted the engine I will be using my original swingarm much the same as I used on the xv1100 last time I was hear pleas don't forget this is shed stuff
Hi there the axle i use is a reliant axle and have used it on every conversion i have done its light so wont ware your gear box out, i alway press out the tubes then press a tube in side of the original tubes to beef it up a little then press s/s over the outer of the original tube this is after striping the axle of all its original brackets the ratio is 3.23 they come in 3 different ratios the other two being 3.54 and a 2.78
Good polish and yokes cleaned and re painted the front end is back on
Lean Machine
Lean Machine
