Results 1 to 3 of 3
Thread: cruise control
    250+ Posts
    Dec 2010
    oly,wa
    Default cruise control
    Good morning
    I am having cruise problems. the way my cruise used to work was I would turn on cruise,(no dash light) when I set the speed then the light comes on. is this normal. it all started with cruise working part time then just quit. I recently replaced master cylinder with new cruise switch. I tried to put the cruise into troubleshooting mode, it doesn't work either. does anyone have a follow the steps procedure to fix this maybe. fuses are good brake lights work
    Dragon
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Your lights are working correctly. I had a problem with mine a couple of times. One time I had to clean out the cruise control module under the hood. I sprayed some cleaner under the cover and everything then worked normally. Another time I had to replace the switches on the steering wheel. Rick
    Stallion #378
    Suzuki Burgman 650
    check the wiring harness at the module for power and ground. you might get a wiring harness diagram for a 2007 ford ranger
  1. Cruise control problem
    By lamornawing in forum Honda Trikes
    Last Post: 03-26-2023, 02:48 PM
  2. Eat broccoli & get a free cruise control!
    By Dante221 in forum Harley Trike Conversions
    Last Post: 08-21-2011, 03:40 PM
  3. Electrical problems - horn, cruise control
    By gctrikeguy in forum Stallion Trikes
    Last Post: 07-23-2011, 07:21 PM
  4. No brake lights...no cruise control
    By ODDOMAN in forum Stallion Trikes
    Last Post: 09-24-2010, 11:38 PM
  5. cruise control issue
    By cowboy in forum General Discussion
    Last Post: 04-07-2008, 05:04 PM
