Likes Likes:  2
Results 1 to 9 of 9
Thread: U Joints - 2008 Honda Goldwing Champion Trike
    Jul 2019
    Joaquin, TX. USA
    Default U Joints - 2008 Honda Goldwing Champion Trike
    Help!!
    U Joint going out on 2008 goldwing champion trike -
    What part number and how to replace?
    Any help appreciated.
    Glenda
    Aug 2020
    South Whitley, IN, USA
    Default Dear Glenda
    Quote Originally Posted by Glenda McGinty View Post
    Help!!
    Glenda
    I also own a 2008 Goldwing with a 2010 Champion conversion. You did not mention if it was a straight axle or independent suspension. Either way, the U-joints should be the same. Has anyone mentioned that the Champion conversion uses a Ford Ranger rear end? Any qualified mechanic either Honda or Ford should be able to identify what you need.
    jessej
    Aug 2020
    Default Champion ownership
    Help!!
    Glenda
    It might interest you to know that Champion has been sold to an outfit in Tempe, AZ. D&D Motorcycles, I think.
    jessej
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Quote Originally Posted by jessej View Post
    jessej
    Champion has used a Toyota Rear axle since 2002. Prior to that they sued a Suzuki rear axle. Lehman has used the 6.75 Ford rear axle and MotorTrike has used a Ford 8" or 8.8 depending on model. The Spicer 5-443X u-joint is used in some Champion Trikes, but I cannot guarantee which you need.
    Jim Murphy
    Iron Butt Rider 2001
    Oct 2020
    Paducah
    jessej
    I own a 2006 Goldwing with a 2018 CRT independent suspension Trike conversion. i got a replacement part # 437-G at Advance Auto. I had to remove the right rear brake pressure assembly to get to and remove the 6 Allan screws with my battery drill impact after heating the pinch block. I easily replaced the u-joints in my bench vise using sockets with the size of the caps and pressed the new caps back in the same method. I paid less than $25 bucks for the u-joint. Good Luck!!!
    jessej
    30+ Posts Ramnight's Avatar
    Jan 2021
    Vicksburg, Michigan USA
    I am wondering the same thing about the U-Joints in a 2012 Wing with the Champion IRS kit. I have called and left messages, and sent them a email on their contact us on their website. But I have not received any replies yet.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Quote Originally Posted by Ramnight View Post
    Jim.....are you using the “Champion Trikes of Arizona” website?
    They are the new owners of Champion in Tempe, Arizona.
    https://championtrikesaz.com/
    Jan 2021
    Quote Originally Posted by paws View Post
    Thank you for the information. I will call them.
    Jan 2021
    No one has called be back, So I pulled the drive shaft yesterday and measured the U-Joints and ordered new ones. I was supprised how easy the shaft came out, and the U-Joints were easy to find.
  1. 2008 Honda Goldwing Champion Trike rear rims
    By Glenda McGinty in forum Champion Trike
    Last Post: 11-30-2019, 05:05 PM
  2. 2008 honda goldwing 1500 stec
    By Samw410 in forum New Member Introductions
    Last Post: 05-08-2018, 08:14 PM
  3. Replies: 4
    Last Post: 05-07-2018, 11:32 AM
  4. 2008 Honda Lehman Goldwing 1800 Trike
    By jimmyfenster in forum Honda Trikes
    Last Post: 08-07-2013, 07:53 AM
  5. GPS 2008 Honda Goldwing
    By skibridg in forum Honda Trikes
    Last Post: 06-27-2011, 11:34 AM
