Likes Likes:  2
Thanks Thanks:  1
Results 1 to 4 of 4
Thread: Lifting a CSC with irs
    150+ Posts geraldlanc's Avatar
    austin tx usa
    Default Lifting a CSC with irs
    In order to change rear tires and replace brakes, how do I get both wheels off the ground at the same time? Using a jack under the dif frame results in only one side going up.
    Gerald
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    You need to lift and block up each side if you want them both in the air at the same time because even if you could get it lifted equally as soon as you take off a wheel on one side or the other you will throw the balance off causing it tip toward the side that still has it's wheel/tire on. Ask me how I know...
    Sep 2016
    Springfield, Mass. USA
    AAAAhhhhhhhhhhhhh good suggestion/advice here...thank you
    3/4/22
    70+ Posts
    Shortstop's Avatar
    Aug 2015
    JACKSONVILLE NC
    Quote Originally Posted by ol' school View Post
    Good advice...been there, done that too.
  1. Do all 2012 and newer CSC Viper's have IRS
    By paid4c4 in forum California Sidecar Trikes
    Owners Forum
    Last Post: 10-28-2020, 07:50 AM
  2. CSC vs MT IRS
    By Mr. Clean in forum Honda Trikes
    Last Post: 07-10-2019, 07:12 AM
  3. Roadsmith irs vs Motor Trike irs
    By david1144 in forum Honda Trikes
    Last Post: 08-31-2015, 10:52 PM
  4. Trike ride quality question on CSC IRS....
    By bamaboy in forum General Discussion
    Last Post: 09-03-2013, 08:38 PM
