Thanks Thanks:  1
Results 1 to 5 of 5
Thread: Correct power connector????
    100+ Posts W3JNP's Avatar
    Nov 2016
    Reading, PA
    Default Correct power connector????
    I plan on adding a heated seat before next winter and have purchased the cable necessary to provide power to the seat.
    I found these two connectors under the left side panel and the cable I purchased marries up nicely with the connector highlighted with the red arrow.
    I “think” that this is the correct connector to provide power to the heated seat.
    Can anyone confirm if this is correct or not?
    THANKS in advance.
    2008 Stallion
    Reading, PA 19606
    100+ Posts NJtony's Avatar
    Oct 2021
    Manahawkin
    Check to see if the brown wire goes to the 10 amp fuse . If it does it is the cooling relay circuit.
    Nov 2016
    Reading, PA
    Quote Originally Posted by NJtony View Post
    Thanks! Will do.
    2008 Stallion
    Reading, PA 19606
    70+ Posts
    Sep 2020
    Gainesville
    Default Here is where I powered my Love Jugs
    I used the bottom plug in your picture to run my Love Jugs
    Nov 2016
    Reading, PA
    Quote Originally Posted by pigfoot63 View Post
    THANKS. Actually the plug I used was the bottom plug. I swapped their positions to make it easier to route the power cable so I am ready to plug the heated seat in when I get it.
    2008 Stallion
    Reading, PA 19606
  1. Heated Gear Connector Location
    By Jerry/MD in forum Harley Trike Conversions
    Last Post: 01-10-2014, 10:55 AM
  2. Transmission Speed Sensor Connector location
    By Craig in forum Harley Trike Conversions
    Last Post: 03-02-2013, 11:43 AM
  3. Installing MP3 player connector on GW1500SE
    By Bighank in forum Honda Trikes
    Last Post: 08-28-2012, 10:08 PM
  4. Replies: 6
    Last Post: 07-05-2012, 01:46 PM
  5. Power...Power, I need more power
    By SJR in forum Harley Trike Conversions
    Last Post: 08-14-2011, 10:37 AM
