SSpoon11hogmemberisoldNew Member Introduct...Hello from VA
SSpoon11ol' schoolNew Member Introduct...Hello from VA
SSpoon11Marc HNew Member Introduct...Hello from VA
SSpoon11ZammyNew Member Introduct...Hello from VA
SSpoon11Uncle FesterNew Member Introduct...Hello from VA
SSpoon11rhino 2New Member Introduct...Hello from VA
SSpoon11trike ladyNew Member Introduct...Hello from VA
SSpoon11SullyNew Member Introduct...Hello from VA
SSpoon11Jack KlarichNew Member Introduct...Hello from VA
SSpoon11GorillaNew Member Introduct...Hello from VA
SSpoon11SSpoonNew Member Introduct...Hello from VA
Likes Likes:  3
Results 1 to 4 of 4
Thread: Tie Down Options
    60+ Posts Tony8's Avatar
    Nov 2017
    Avon,Ohio USA
    Default Tie Down Options
    Hello everyone. I have a 2016 GL1800 Goldwing Trike with a CSC Viper trike kit installed. When trailing the trike, I know where to tie it down in the back but securing the front has me baffled. Where should I tie it down on the front? Also should the front suspension be compressed a little bit?
    When trailing the trike should it be in neutral or 1st gear after tying it down?
    Thank you,
    Tony
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Hi Tony! Welcome to Trike Talk! Page 25 in the CSC Trike Owners Manual explains it and has a diagram...
    https://img1.wsimg.com/blobby/go/196...=1650386198475
    Quote Originally Posted by Tony8 View Post
    Thank you,
    Tony
    Apples 🍎 to Oranges 🍊 ??? But with my Tri-Glides I always trailer in gear with park brake on .
    And I run a ratchet strap through the front wheel careful of the roaders and with a soft towel between the rim and strap so as not to abased it—Hope this might help you…
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    I installed a front motorcycle wheel chalk on my trailer. It is a ride in cradle that secures the front wheel. I then run a heavy-duty tie-down strap through the front wheel at about the 10 o'clock position. That strap then extends down and forward to anchor points at the front corners of the trailer. This secures the front of the trike and prevents any movement forward, backward, or from side to side. I use a good pad on the wheel to prevent any abrasion of the strap.
    I have a friend that hauled his Goldwing trike cross country with it in gear. He had to have expensive transmission repair work done after doing so. I leave mine in neutral. Two rear straps to the back corners of the trailer prevents side to side movement of the rear end. I do not compress anything on the front fork. The trike likes to ride on its own suspension. It never moves and nothing is broken when I get to my destination..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
  1. How do you tie down a trike on a trailer?
    By Golden Dakota in forum Trailers / Campers
    Last Post: 06-13-2014, 02:20 PM
  2. Trike Tie Down
    By Blueribbon in forum Accessories
    Last Post: 12-13-2012, 06:39 AM
  3. Trike Tie Down Recommendations
    By ladywingrider in forum Honda Trikes
    Last Post: 08-29-2012, 08:28 AM
  4. How to tie down a trike??
    By rickt in forum Honda Trikes
    Last Post: 11-22-2010, 09:36 AM
  5. How to tie down a trike
    By Jimsjinx in forum Trailers / Campers
    Last Post: 01-28-2010, 10:18 AM
