Likes Likes:  1
Results 1 to 6 of 6
Thread: Roadsmith left turn signal assembly:
    Apr 2022
    Saukville,Wisconsin, U.S.A,
    Default Roadsmith left turn signal assembly:
    Hey folks,
    Kinda of a serious question.
    We own a 2016 Roadmaster with the Roadsmith Trike kit.
    The issue I have is the left turn signal (rear) doesn't not work.
    IT IS NOT THE BULB!!!!!
    When I changed out the bulb I noticed the marker light flickered a bit while inserting the bulb.
    I'm hoping it's just a loose wire BUT..
    HOW do I get the assembly off to check the wires?
    I can get the lens off and the reflector out, but have no access to any screws or such to remove the actual assembly.
    ANY info will by grateful.
  2. Roadsmith banner
  3. #2
    Thumbs up
    Quote Originally Posted by Digg View Post
    Hey folks,
    Donald welcome to Trike Talk👍👍..
    I can’t help you on your problem but I’m sure somebody will chime in soon and can help you with information you need..
  4. #3
    Hey folks,
    Welcome aboard. Did you look behind the fender to see if it was thru bolted possible? Also RoadSmith is located in Wisconsin try calling them direct. Good Luck
  5. #4
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Better still - just about 4 hours from you - sounds like a nice trip
  6. #5
    200+ Posts
    Nov 2010
    CALHAN COL.
    Default roadsmith
    WRONG THEY ARE IN MINNASOTA
    Quote Originally Posted by BIG DENNY View Post
    wRONG THEY ARE IN mINNASOTA
    Correct, here is their contact info
    https://roadsmithtrikes.com/contact-us/
  1. Roadsmith Turn Signal
    By Blueribbon in forum Honda Trikes
    Last Post: 08-25-2014, 09:02 AM
  2. turn signal prblm on vtx1300MT
    By tipper in forum Honda Trikes
    Last Post: 07-11-2012, 04:56 PM
  3. Got a turn signal issue....
    By krooozn in forum Honda Trikes
    Last Post: 03-29-2011, 10:49 PM
  4. Turn Signal Cancellation
    By bluesuedeshoes in forum Harley Trike Conversions
    Last Post: 12-11-2009, 11:12 AM
