Likes Likes:  8
Results 1 to 9 of 9
Thread: trike brake parts
    Oct 2022
    Crewe
    Default trike brake parts
    hi all
    just about to take delivery of a 2000 Honda gl1500 trike ,I'm not sure when the conversion was done but having paid out when i got back home i couldn't help but think that whilst i knew lots about the 1500 i knew nothing about the trike
    The first thing that sprung to mind was what happens when its due rear pads and discs ,so how do i firstly find out what the rear end is off ?
    what's worrying my is i might be left with 11000 worth of unusable trike
    thanks in advance for any help
    Quote Originally Posted by thewingeruk View Post
    hi all
    Post a picture of your brakes, that will help identify them
    Apr 2010
    Shenandoah Valley of Virginia
    Don't be surprised if it has Ford 9" drum brakes like a 1980 Pinto. Solid axle likely is a Ford 6.75 integral Pinto axle shortened. Rear universal is likely a big cap Ford 1310 series, thicker caps under the u-bolts retention in rear yoke. Drive shaft might be a GL 1500 shaft cut and welded in a yoke or it might be a splined shaft with 3/8" set screw retainer. Front U-joint is either a GL1500 or Valkyrie U-joint Not junk, it's all available but it will pay you handsomely to know what you have.
    Here is a picture of typical Ford drum brakes
    Oct 2022
    Crewe
    Default THANKS
    Thanks for the quick replies guys sounds like I'll go ahead with the purchase and send photos once it arrives at the end of the week
    once again thanks all
    Apr 2010
    Only thing I really wanted to add, this is a left rear brake, long shoes at rear, short shoes in front.
    Really a nice picture with no brake dust covering everything.
    A great picture for someone who maybe forgot the order. I always lay parts on the floor in a pattern that will aid in replacement, one can get anything for these Ford drum brakes. I do one brake at a time.
    Friend of mine decided to reline his old Mustang's drum brakes ... He took all the parts off all 4 drums and put them in a bucket to clean, then realized he had no idea how to separate the parts or to reassemble his brakes with new shoes. He did have clean stuff, but what a mess.
    Oct 2022
    Crewe
    Default brake drums
    I bought the trike ,is any one able to identify what the brake drums are off its a 2000 1500 gold wing with a lehman trike
Size:  111.2 KBName:  IMG-20221121-WA0005.jpg
    Mazda pickup
    Apr 2010
    Looks like a 9" Ford brake drum to me, even to the number 212043-C stamping ... and the fins. I just looked up a 1980 Ford Pinto brake drum but my '92 Thunderbird had the same rear brakes as do a lot of older Fords with drum rear brakes. You'll often see them listed as 1-3/4" wide or sometimes as 1.81" wide shoes. They did play with rear wheel cylinder diameters as a way of tailering them to application. I used to have a lot of info, but after I sent it back home to the original owner in 2019, most of it seems to have gotten away. I owned it 15 years though. If ever replacing wheel cylinders, might have to measure your's.
    More Information for ACDELCO 18B21 (rockauto.com)
    Post in another thread has some other info you might need someday?
    Brake shoes ... 9" Ford Drum Brakes ... Some numbers to help guide you. Most of it is like late '70s or early '80 Ford Pinto, Mustang II, etc. Even up into the '90s Ford used a lot of 9" drum brakes on cars. Your rear axle is a 6.75" integral carrier rear with a stamp steel rear inspection plate, but they came with one of two different gaskets, square looks like a square with 4 rounded corners, octagonal has 8 sides, no curves. Keep in mind that these numbers are from the latest GTL book I had, Many will need to be cross referenced.
    You can experiment with other rear wheel cylinders too, Ford made them in several diameters. Bigger will increase braking force while decreasing effort but increases travel, smaller will decrease brake force requiring more effort but decreases travel. It's a balancing act, I played with them but in the end, went back to the sizes as Lehman used.
    Description ... Lehman Number ... Vendor Pt No ... Vendor
    Brake Shoes GB1118 474RP Raybestos
    Lt Brake Adjuster Kit GB1110 2592 EIS
    Rt Brake Adjuster Kit GB1112 2593 EIS
    Brake Spring Kit GB1124 7157 EIS
    Wheel Cylinders GB1122 EW34958 TRU-TECH
    12" brake line GB1132 AS312 Papco
    30" brake line GB1135 AS330 Papco
    40" brake line GB1136 AS340 Papco
    Diff. Cover Gasket
    (oct) GG0650 RDS 13073 Fel Pro
    (squ) GG0650-0 RDS 55323 Fel Pro
    Axle Bearing GB1001 RW207 CCRA BCA
    Axle Flange Gaskets GG0600 n/a (?) AGS
    Park Brake Cable GB1114 370100 ABSCO
    Brake Drum GB1120 857 ITT
    Axle Stud CS1001 560-186 Papco
    Brake Shoe Retainer GB1119 D7TZ2028B Ford
    Pinion Seal GS1056 8181 NA (?) National
    Axle Seal
    (25 spline shaft drive) GS105 3214 National
    (23 spline shaft drive) GS1050 3199 National
    Park Brake Handle GB1100-0 30011810 Chevrolet
    FLH Debris Guard LS1018 300026 Lehman
    Sportster Debris Guard LS1017 n/a Lehman
    Debris Guard Bracket LB1181 n/a Lehman
    Speedi Sleeve (shft drv) GS1058 99181 National
  1. Rear brake lines/parts
    By C Dog in forum Harley Trike Conversions
    Last Post: 07-17-2020, 05:58 AM
  2. 2005 Honda VTX 1300R-Champion Trike- Brake parts?
    By sqeeter91 in forum Honda Trikes
    Last Post: 09-02-2014, 06:39 AM
  3. brake parts motor trike
    By driver10 in forum Motor Trike
    Last Post: 05-14-2013, 10:57 AM
