Likes Likes:  6
Results 1 to 8 of 8
Thread: Trim Over 1 Wheel Is Hanging Off
    5+ Posts Ginger Gypsy's Avatar
    Dec 2022
    Upper Marlboro, Maryland
    Default Trim Over 1 Wheel Is Hanging Off
    Hi. The trim over one of the rear wheels on my trike is hanging off of the trike. What would be the best glue to glue it back on.
    Thanks!!
    Quote Originally Posted by Ginger Gypsy View Post
    Thanks!!
    Beacon 527 Glue…. Available at Walmart and many other stores.
    Sep 2016
    Springfield, Mass. USA
    Grilla super glue ........... that save'd my trim as well also
    12/26/22
    Jan 2009
    MA,
    I would think it was originally put on with double face tape, Take it off clean everything good retape it and put it back on. I have seen where people have had car moldings fall off , and they try every type of glue to hold them on, there's glue and crap all over the moldings & body, come to the shop and want it fixed correctly what do you do with but buy new moldings & repaint the panels that they screwed up, Better yet go to a body shop have them fix it wright the first time .
    Apr 2010
    Shenandoah Valley of Virginia
    Is it a chrome hard plastic fixed shape trim ... or is it a chrome flexable type mylar trim?
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    If using the 3m double sided tape, make sure to thoroughly clean the area that you will be applying the tape to as well as the item being attached. Then use some isopropyl alcohol to clean it again. There is also a product called adhesive promoter that helps with making sure the adhesive tape works even better. It's a bit pricey which is why many will skip it but it does work really well...
    3M 4298 Adhesion Promoter, 5 Sponge Applicators (Choose 5 or 25 Qty) https://a.co/d/bZwR7uh
    Dec 2022
    Thanks all. I ended up getting a shop to do it so I wouldn't mess up the paint on the trike. I have shaky hands. The trim is firm.
  1. Replies: 11
    Last Post: 05-14-2011, 08:00 PM
