Likes Likes:  8
Thanks Thanks:  3
Results 1 to 14 of 14
Thread: Loose baffle
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Default Loose baffle
    I had my exhaust pipes off today and I noticed a loose baffle in the left pipe. Everything looks solid when you look down the back end of the pipe but when you shake it you could hear it rattle. Anybody had this problem before? It's not causing any problems you can't hear it when it runs but I noticed it when I took it off. It doesn't sound like rust or carbon inside the pipe it sounds like a solid 'thunk'.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
    I have a loose baffle and loose fiberglass wrap on my RS Freewheeler , it is mildly annoying some times
    Jack…..Just power up the old boom box a little louder..The typical Harley rattle’s will then disappear 🫠 😉…Kinda like when the grandkids are arguing with each other..I just raise the volume on the Doo’Wop music and then the kids just go away..😉..
    Oct 2018
    Ramseur NC USA
    Quote Originally Posted by Rogue1 View Post
    P.S. They are stock mufflers, I took the fishtails off.
    Mine are stock also, HD M8 stock baffles are short and welded in around the back opening, this is where they rattle, poor job by HD
    It might just be welding slag that was never clean/blown out..?
    No, the plate @ the end of the baffle is too thin, that cannot support the length of the baffle so it starts to vibrate. Very weak design IMO
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    I have a set of stock muffs from my 2020 removed when new that I would like to sell
    Oct 2018
    Ramseur NC USA
    Default Really loose baffle
    That loose baffle I mentioned back in April is now really loose. Sounds like hell going down the road. I got about a mile before I realized what it was and had to turn around and go back. Looks like I'll be putting my fishtails back on until I can figure out what I want to do. At least I have a choice.
  11. #10
    When you take the muffler off again, shake it. Do you hear anything?
    The fiberglass works loose and makes a lot of noise also, on my 17 I pulled them both off and removed the wrap, noise was all but gone
  12. #11
    Oct 2018
    Ramseur NC USA
    When I hold the muffler vertical and then flip it 180° I hear a thunk. I turn it back around 180° I hear another thunk. All I can think of is the fiberglass is in one piece it just came loose from the inside of the muffler. When I turn it upside down and back around I think it slides a couple inches one way or the other and that's when I hear the thunk. I haven't figured out how to get the fiberglass out yet.
  13. #12
    When you have it off the trike, use a metal coat hanger with a bit of a hook on the end, reach in thru the opposite end, twist it around and pull, some will come out, repeat and shake it upside down, the wrap will fall out
    I have an extra long screwdriver that I use to get it started also
  14. #13
    Oct 2018
    Ramseur NC USA
    I have an extra long screwdriver that I can use and use the coat hanger method. I have them both off now so first thing in the morning I'll go out and see what I can do. I don't know what else is in there that would rattle and make noise.
  15. #14
    Good luck, while you are at it, grab the (on the outlet) with a pair of channel locks and see how much it wiggles, if little to no movement chances are the wrap is moving causing the noise, after stripping my 17 of the wrap most all of the noise was gone
    Give the muffler hangers a bit of lube when you put them back on, if you have silglide or white lithium grease lube them now
  1. Fork mounted air baffle available?
    By Thor in forum Harley Tri Glide
    Last Post: 05-05-2023, 07:26 PM
  2. 2010 Tri Glide Ultra. Baffle recommendations
    By pcmikey in forum Harley Tri Glide
    Last Post: 12-26-2013, 05:43 AM
  3. My fork baffle install....
    By JohnC in forum Harley Trike Conversions
    Last Post: 03-26-2012, 05:14 AM
  4. another benefit fo dennis's wings and baffle.
    By tkglider in forum Harley Trike Conversions
    Last Post: 02-22-2012, 08:50 PM
  5. Review:Wings and Baffle
    Last Post: 02-17-2012, 12:03 PM
