Likes Likes:  8
Thanks Thanks:  4
Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 121 to 140 of 159
Thread: Stallion Parts & Maintenance Reference
  1. #121
    20+ Posts
    Dec 2011
    West Valley City, Utah Salt Lake
    Default Re: Stallion Parts & Maintenance Reference
    I have been thinking about replacing mine with the xeono lights. It sounds like the are brighter and take less wattage. Also thinking about replaceing the headlights with them, it looks like they will fit but will have to make a new bracket to hold them.
  2. #122
    Quote Originally Posted by Dartz View Post
    If you do please post some how to do pictures and instructions please.
  3. #123
    20+ Posts
    Apr 2014
    El Paso, TX
    I was wondering if anyone has loose calipers on their Stallion? I can move them approximately 1/16 to 1/8". That movement causes a banging noise makes it sound like something is falling off the front end.
  4. #124
    30+ Posts DrSign's Avatar
    Jun 2014
    Elkton, FL USA
    well suggest that you start trouble shooting. Look to see if you have power to the bulbs with the switch on. Check for a blown fuse. If factory switch is bad suggest just wiring them with a replacement switch. The bulbs can be replaced in the housing. You have to solder the wires in but it beats buying new lights. I believe the buld is a H-3 100 watt. I would suggest substituting with 50 w they last a lot longer and the difference in light is not that much.
    hi! I got a blown left bulb after just one day! How do I get the bulb out of the base? I don't want to force it and have it shatter!
  5. #125
    Quote Originally Posted by DrSign View Post
    You have to take it apart. I believe there are 4 screws to remove and it all comes apart. You will have to cut and solder the wires to the new bulb wires.
  6. #126
    60+ Posts
    Apr 2013
    Altoona Pa. USA
    I had to fix mt fog lights. Fuse was good, relay was good. The problem was in the headlight switch, After taking apart the switch I found a tiny white micro switch located in the cricut board was dirty and sticking. The black center post inside the switch makes it work when pulled out. I cleaned it good with electronic contact cleaner and it fixed the problem.
  7. #127
    Sep 2014
    atlanta, ga, usa
    Default Re: Stallion Parts & Maintenance Reference _ foglights & radio/CD player
    Quote Originally Posted by Road Rider View Post
    My foglights would intermittently switch on and off AFTER THE ENGINE WAS TURNED OFF. Eventually drained the battery.
    Thanks for the heads-up! I will check it out.
    BTW: another issue - Does ANYONE know if the radio/CD in the trunk should 'power off' when you turn it off from the dashboard control, OR, does it remain in a 'power-on standby' mode until wanted?
  8. #128
    20+ Posts
    Apr 2014
    El Paso, TX
    Default Re: Stallion Shock Absorbers
    I thought I read in the maintenance thread about someone having issues with their shock absorbers. It's interesting I can go to either side of my Stallion and raise it about an 1" or 2" by hand. If anyone has or had this problem please let me know. Plus does anyone know what the replacement shock absorbers are for the trike?
    John
  9. #129
    250+ Posts
    Dec 2010
    oly,wa
    Hello
    I just replaced my front shocks because the rubber
    mounting bushings on the shock were wearing out
    and allowed the shock itself to contact the swing arm
    almost wearing a hole in the shock. the new shocks have different
    mounts. as for shocks they are made for stallion, you have to get them
    from TBMS
    Dragon
  10. #130
    100+ Posts Las Vegas Biker's Avatar
    Dec 2010
    Las Vegas, Nv USA
    Mattel, I had my turn and brake lights replaced with led and they are working fine. I believe they came from auto zone, plug and play type.
    Terry
  11. #131
    Sep 2015
    Owensboro
    Default Loose steering.
    I'm experiencing play (where the steering wheel will turn a little either direction before the tire responds) The play seems to be in the steering rack and pinion. There doesn't appear to any loose motion any where else in the steering system. The front wheel bearings appear to be in good condition.
  12. #132
    first welcome aboard. second stallions do not have rack and pinion steering. what you may want to look at is the steering head bearings. I expect if you take the triple trees apart the bearings need replacement and the whole head re-greased, that will tighten up your situation and you will be surprised at how well it steers. do not hold back on the grease.
  13. #133
    300+ Posts
    Signal Mountain Tn
    Quote Originally Posted by funtimes View Post
    There is actually an adjustment on the steering box. It is hard to see, and very tricky to adjust. You will see a slotted screw protruding from the gear box with a jam nut on it. You won't be able to get anything on the slot. What I did was to start another narrow nut on the threads and run it almost to the original jam nut, then back back it off against the temporary nut, then you will be able to turn the adjustment portion. I believe the adjustment screw is a 5/16" fine thread.
  14. #134
    Sep 2015
    Owensboro
    Default Thanks
    Thanks, for the welcome.
    Quote Originally Posted by trikervet View Post
    Sorry for the incorrect terminology. When I young the people I knew referred to the steering gear box, as a steering sector.
    I just accepted it.
    A couple of questions.
    1. Do you know what car TMS used for the Stallion steering gear box.
    2. Did you have a similar problem.
  15. #135
    20+ Posts
    Apr 2014
    El Paso, TX
    Default Rear shock absorbers
    Has anyone replaced the rear shocks on their Stallion? If so what did you go with.
  16. #136
    Good question looking for an answer to that from the group also.
  17. #137
    30+ Posts
    Jun 2018
    KINGSTON, new york, ulster
    Default air wings for 08' stallion
    Hello
    I am Thor 27.
    i have a 08' stallion.
    i was hoping that some one knows where to get air wings for it.
    and is any one making wind shields?
  18. #138
    Mar 2020
    Loogootee Indiana United States
    Default Need to know where to get parts?
    Hi all my Dad passed going on two years now, and i became the owner of a stallion.. ive been working on it doing some things that need done. 2009 is the year... I need parts, as i have no idea where to start looking for them. I knocked the left front rear view mirror off the other day and broke the amber lens for it. Any ideas on that for starters. I have read on the front brakes and changing them. I see two different ways on here, and if its possible to not/ take the front wheel of i would prefer that. And from what im seeing brake pads are from a toyota fj cruiser. Is this correct and i think it means the ones from the back of the toyota. i just need to know where to get parts for this thing. It was my dads baby and i want to do it right..... please help
  19. #139
    Sep 2020
    Livingston, TX
    Default 2013 Stallion Driver backrest needed
    We just bought our 2013 Stallion, but it was missing the driver backrest. We can’t seem to find one.
    Help!
  20. #140
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Andrew, I cannot help you, but I can offer you a big .
  1. Used trike reference pricee
    By ben721364 in forum General Discussion
    Last Post: 04-27-2013, 10:43 AM
  2. Reference material
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 02-07-2013, 10:16 AM
  3. Necessary maintenance
    By spiritdream in forum General Discussion
    Last Post: 06-02-2010, 11:59 AM
  4. Changes to the Stallion or New Aftermarket Parts?
    By Mattel in forum Stallion Trikes
    Last Post: 10-26-2008, 08:06 PM
Tags for this Thread
