Pro Action Rear Shock Intall Today With Lots Of Pic's On 2017 Tri Glide
Mar 5, 2015
474
354
Bakersfield California USA
Today I jacked up the 2017 Tri Glide and installed my new Pro Action rear shocks from DK Customs. I just went through the fender wells, really no big deal to do.
A few things I will list to help other with this task.
#1 Lift trike and place on jack stands remove tires and wheels. Place strap around grip and front brake lever holding front brake on and chalk front tire. (See Pic's)
#2 The bottom shock bolts are a hair to long in my opinion (see pic's). I first noticed this on my 2015 Freewheeler when I installed the Comfort Lift. Before starting the shock removal I trimmed about 3 threads of the end of the lower shock bolts before removing them with my thin blade trimmer. Let me explain why I did this. The head of the bolt when backed out all the way hits the frame and the shock dose not want to come out (also will scratch the heck out of the frame). With 3 threads removed it will rock right out of the lower shock mount bracket after the top shock bolt is removed. NOTE with the 3 threads removed the bolt it just comes clear of the threads in the lower shock bracket and the head rest right at the frame and as stated will rock right out after the top shock bolt is removed.
NOTE on the left side to trim the 3 threads of the lower shock bolt if one decides to do this you need to remove and pull the emergency brake cables over out of the way (see pic's).
#3 The right side shock went on easy and threaded right on to the shock mounting brackets top and bottom.
The left shock did not. I had to put a little pressure down ward on the swingarm by placing a padded short bar or long screwdriver between the frame and bottom shock bracket and pull down a little to get the shock bolt straight so it would thread into the lower shock bracket.(I think this was because the drive belt held a little upward tension on the left side). It did not take much effort at all for the bolt to line up.
Then I painted the ends of the bolts where they had been trimmed the 3 threads removed so there would be no rust issues.
It is rainy today so I will give a ride report later.
Ride Safe All, :)
Bill G
I gotta ask'''' How in the world do you keep the underside of your Trike clean... Like in spotless....:Shrug:
Well two things play into this..
#1 The trike is pretty new #2 Once a month I put my trike on my J&S Jack trike lift, then I lay underneath it and wipe everything down with a micro fiber cloth soaked in hot water and then rung out. Over all this keeps things pretty clean and allows me to inspect everything.
I tend to to be a little anal about things.....Lol :D
:pepper::pepper: :pepper:
Ride Safe All,
Bill G
Good to see you have them installed. Looking forward to hearing how you like the ride!
I went for a short couple of solo rides this afternoon and the shocks feel excellent Kevin.They tend to absorb the small bumps and imperfections in the road and pretty much float over them. I set them from the 5 clicks they were set at to 4 clicks on the second run out through the country this afternoon (this setting felt even better to me). The rest including sag and spring pre load seemed to be spot on.
I will have or get a better feel for the new Pro Action rear shocks after a long two up ride with my better half. I hope to be getting that done soon weather permitting.
Take Care & Ride Safe,
Bill G
Underbody car wash:laugh::laugh: looking forward to your report
All for now Trampas
Not quite Trampas but darn close the way I do it keep it clean listed above.....Lol
Ride Safe, :)
Bill G
VERY good write-up Bill........although I don't have a Free it's articles/input like yours that make this site what it is.......EXCELLENT!
Enjoy the ride my friend,
ThumbUpThumbUp
Thank you friend,
Please look over the spelling errors, I really stink at typing and grammar sometimes....Lol at myself :)
Ride Safe,
Bill G
Looking at your pictures, i saw which shock you installed. Can you tell me why you chose that one over the other they offer at Pro. ?
For me I just decided to by the USA built shock ( support a USA company) with the limited lifetime warranty over the two year on the Bitubo Italian made shocks. Also I felt it would be easier to deal with a USA company if there was ever a warranty issue.
DK Custom claims no noticeable ride diffrence between the two shock brand offerings. So it really just comes down to a personal choice.
Ride Safe All,
Bill G
Ride Safe All,
Bill G
I thought there were 2 diff. Pro Action
Did my 2015 almost the same. Secured the front wheel down to the floor, floor jacks (plural) at the normal jacking point and supported the rear at the bumper brackets. Didn't deal with the park brake bracket. I just loosened the lower shock mount bracket enough to get the bottom bolt out. Left side took almost an hour and a half. Knew what to do on the right side, 20 minutes. Have ridden only twice since but love there is no more bottoming out, even 2up, and sooooo much smoother on secondary roads where we ride the most. I put them in right out of the box. Was going to firm them up first but thought if they wanted all that info first, why not try it. Thank you DK Customs.
Ride Safe All,
Bill G
:pepper::Agree:, great choice and great reason!!
Roger
DK Customs sells two styles of rear shocks, one is manufactured by Pro Action there street series line a USA company. The other shocks are manufactured by Bitubo out of Italy an Italian company. The Bitubo twin action shocks cost $252.00 less. DK Custom claims no noticeable diffrence in ride between the two in there testing.
DK has a full right up on there web page concerning the differences between the build and warranty between the two brands of shocks.
Ride Safe, :)
Bill G
I wasn't thinking when I posted earlier, I know you have the J & S jack and was wondering why you didn't use it instead of the method you used, just curious, I know with the jack you wouldn't have to strap the front brake lever at all, I seen your two little floor jacks, which I don't have but why use the jack stands, I may not be thinking this thru just right but if you could explain why this way you did it instead of using the J & S jack could help out, inquiring minds that might be doing this down the road to help them decide if they could do this themselves or hire it done.
As for your under body carriage being clean, I'm the same way, I'm anal about keeping all my bikes and my truck clean.
All for now Trampas
There are many different Pro-Action Configurations/lengths/spring weights/valving, and the same for the Twin Adjustable Bitubo Shocks.
See more info HERE
Good to hear you both are enjoying a more comfortable ride!
As for your under body carriage being clean, I'm the same way, I'm anal about keeping all my bikes and my truck clean.g
All for now Trampas
Trampas,
The reason I did not use the J&S Jack trike lift for the rear shock removal is because it supports the trike on the front of the swing arm underneath the trike (see pic). I needed the swingarm and rear axle to move freely not supporting any of the trikes weight to remove and install the rear shocks. This allowed me to jack up or lower the swingarm and axle freely if needed to get the shocks back on or in place. The jack stands supported the frame only not the swingarm or axle.
In the pic below you can see the J&S Jacks rear support lift arm lifting on the trikes swingarm behind the exaust crossover. This lift arms mechanism is cable operated into place after the trike jack has been placed under the trike. You can see the arms lift mechanism in the pic.
Ride Safe Friend, :)
Bill G
yantwohands
yantwohands
