Best accessory you put on your trike and why
Air horns. They really get the "air-heads" attention. The good ones are much louder than stock horns. I'm running a Stobel that's plenty loud for me, but there may be better ones I don't know about. Any good horn will likely require a relay.
PC
My bike was used when I bought it and has a good amount of extra lighting. That would have been my first addition in order to be seen. The biggest bang for my buck so far has been a fork brace. The bike handled pretty good before but after installing a brace it is much better and I do believe the steering is a bit easier...... Jim
I had a 12 volt plug installed in the storage compartment on the left side. I mounted a RAM GPS holder that bolts onto my clutch reservoir for my standard $99 GPS. Not only does it help when I need directions it shows me when there is a sharp curve coming and which direction so I can navigate which side of the road I want to be on. It also comes in handy when I go on my "ride to nowhere" so I can actually get home the same day! LOL
Ne farmer, Using a piece of 3/4" angle iron I mounted the air horn right where the stock horn was. Painted everything flat black so it blends in with the engine.
PC
2+2 wide sweepers made all the difference in the world on riding my Trike. Second will probably be the MT mechanical reverse I just ordered.
X_RfjCf6hQofYyjaQYX9tXZ3VEI3FrynT_GuQ7w1CgzXmChYAqBqlSG42H9MvYdRlTqw3abSjKvuUemKh3cXzK_n_7Lis2mfBw
:D
Like Jack I think the Mini Might Fans. Close second is the 2+2 Wide sweepers if I didn't swap them I would have sold the Trike.
Not trying to highjack the thread but I looked the 2t2 wide sweepers up on JP Cycles and it said they would not fit my 2017 Tri? And the best accessary I have put on my trike is my butt in the seat:laugh:.
Call Khrome Werks and talk to them really nice people they let me know it would fit my 09. J&P said the same thing then. Fred
It would be a toss up I think ... but, I love what the Power Vision has done for the trike.
A close second would be the 14" Pro Action Shocks and Accompanying Comfort Lift.
Both purchased from DK Custom.
Third would be the Mighty Mites ... purchased from Zook.
I have installed air horns great safety investment
PC
Good message neighbor, I have a 1800 Goldwing Champion Trike. I also took extra safety measures and installed me a set of air horns on my trike. I found a set on Amazon that is amazingly loud and not expensive. I ordered two covers to keep the bugs and water out. Of course they are wired with a relay. Lots of room beneith my trike for the pump and relay.
Stockville69
Stockville69
