Got delayed again.... Plus, I've been doing some more digging into the possibility of this issue being the Secondary Master Cylinder (SMC). That, along with the Residual Check Valve & Proportional Control Valve (PCV). I'd like to at least change the check valve due to having to re-bleed everything again but first, I have to figure out how to get at it with both hands. It is made by a company named Wilwood which is stamped on the valve. One thread here in the forum gave the part number 260-3501 along with Lehmans GC6003 (link below). While taking some pic's, I went ahead and took some of my hydraulic lines and labeled them (below). There are areas of the lines that I can't physically see therefore, it could be labeled inaccurately but, I.M.O. it's correct.
Residual Check Valve: https://www.triketalk.com/forum/threads/8732-Residual-brake-valve-on-Lehman-Monarch-1
