Dumb (?) Nuvi Question
87Trike1200
TOI - New Jersey
Feb 23, 2008
5,354
358
The Jersey Shore
I have a Garmin Nuvi 2555 that I've used successfully both in my car and in the side, drivers window of a 45' tour bus. No problems - works great. Recently, with the correct Ram mount, I used it on my GL1500. Seems to work OK but occasionally a "pop up" message appears telling me I should be using an external antenna for best accuracy. I don't "get it" since the device sits out in the open with no "overhead" obstructions. The "pop up" stays on for 10 or 15 seconds, goes away, then we're "back to normal" until the message re-appears - maybe 10 minutes later (+ or -). Until using it on the bike, I never even saw this "pop-up" before.
This is not really a big deal except it's annoying and for the "mystery" of why it thinks an external antenna is required. Do any of you electronic "gurus" have an explanation? Thanks.
I'm thinking your flux capacitor might be on the fritz!:D
To try and give a semi serious answer to your question is it possible that the mass of metal from the first two vehicles acts as an antenna booster while the 1500's largely plastic body does not?
Is there possibly something on the ram mount that is shielding the antenna on your Garmin? My only thought.
Gorilla - good thought, I will investigate.
Just a thought have you tried Garmin for their input?RIDE SAFE
Didn't try Garmin yet (I will). I thought some of the TT folks might have had a similar incident and already know the "magic answer/cure".
Overall, it's probably not a big deal - more of a puzzle. :Shrug: Thank you to all for taking the time to reply (even the "goofy" answers were entertaining). :D ThumbUp
I used my Navi on a flight from Houston to Cinci and you should have heard that little voice every five seconds saying "recalculating" That little device was "smokin"
rramo
