Rear Shock
Has anyone tried to use a stand alone shock without the airbag setup? 2014 RT. I cannot get a decent ride on this machine no matter where the air pressure is (40 _65 psi ) It seems like the airbag only is doing the suspension. 24 K on the machine. Nothing but rough roads in Northern Indiana also..... It has always been a rough ride, maybe the shock ( whatever it doe's) has never been anygood..
Welcome Jack 'To Trike-Talk....:wave4: If you think your roads are rough, Just take a ride out my way in New Jersey, Some of our pot holes are deep enough to lose Jimmy Hoffa in....:laugh:....Wish i could help you i gave up my Spyder a few years ago, But I'm sure someone will come on with the help you need...Agin ...Welcome...:clapping:
rough roads
Yes the roads are bad. I came across a smooth secton and almost lost control. Soon they will all be toll roads and one will pay for the holes we drive in.......
what do you mean by decent ride? :confused:
What air pressure are your tires set at? :xzqxz:
Are you sure the compressor is working and not leaking air too?
Do not have a compressor, and I have no leaks, tried pressure from 45-70 and stil have a harsh ride. Tires are, 28 rear and 20 fronts. Thanks
Ok now I am confused. You have a 2014 RT Spyder with no air compressor that is mounted on the bike for the rear shock??
OK lets try this.:xzqxz:
You adjust your rear shock with a shock pump by hand and have disconnected the on board air compressor? :confused:
My Spyder is the very stock RT, Air is adjusted under the seat with Schrader valve. My spyder has no extras, it is a plain machine. The dealer I got it from says he cannot give away this model as it is so plain. It is a 2014 RT SE6........
Well I have a 2014 Rt and have a air compressor. I wasn't aware the Rt was made without one. I know the Rts has a few less chrome things but the compressor is still t there
My dealer told me to use 24 in rear and 18 in front, on my F3 Limited. Not what the book calls for, but his recommendation. Being an F3, it rides a little rougher than an RT anyway, I think. My wife's says her RT rides smooth at 28 rear, 15 front. Good luck and keep adjusting until you get what works for you!
since I found out a basis RT does not have a compressor. Like above stated adjust till you are comfortable.
But also does the rear raise up and down when you put in air. And how are you putting in air with what type of device??
shock
Never had a pump, plain jane RT's the air is done manually under the seat with the schrader valve. Still would like to know just what the shock doe's which in my case is not much......
It's should stiffen up or soften the ride over bumpy retain when used with air. You want a better shock Ella has then but pricey. They set it up to your weight and how you ride
Shock
Yes, it goe's up and down when air added, use a compressor carefully to get desired psi. I can push down on the passenger handles about four inches, and that goes away when we get on. No matter where the psi is (45-65) it has always been that way so it is hard to tell if the shock is doing anything. Combined weight on the machine is less then #300 lbs..
There never was a compressor on this model RT SE6 it is a basic RT. Adjust air under the seat via Schrader valve.
I'm guessing you've tried an old fashioned bicycle pump then...you could definitely 'fine tune' it much easier that way.
I don't know...I'm at the end of a 10 hour shift, so I'm not thinking straight.:seestars:
Gump13
