DK Custom Products
Sponsor
Spent a few hours with a Milwaukee-Eight Today - First Impressions Report
Went to a dealership today and spent a few hours with the M8.
First thing I did was ride a Street Glide (no one in our area has any 2017 Tri-Glides yet). Then after I rode it, Devin took it out for a spin.
We both experienced the same things-
It shakes less, but still has some.
The compensator is definitely better...how long it will last is yet to be seen.
The power comes on MUCH lower, and there is more of it. Bone stock it is, seat of the pants, very close to a typical Stage I 103, EXCEPT the power is there much lower in the RPM band.
On a 103 if you twist the throttle at 60 mph in 6th gear (not recommended) it will do close to nothing...it is just a dog, and is very apparent that it is lugging.
On the M8 107, same twist at 60 mph in 6th and off it goes.
There is less mechanical noise.
Exhaust sounded about the same as the 103's, but I imagine that with some slip-ons and with the M8 having a lower (850 RPM) idle, it will sound pretty good.
The EITMS still kicks on very easily. It does not seem to be ambient temp controlled.
After a short 11 mile circle it kicked on at 85* ambient for me, and then 87* ambient for Devin.
The cat is located further back on the bike, so there was not as much felt heat on the right leg from it.
The rear suspension is better than the HD air shocks, and better than HD's previous "premium coil-over" shocks, but still not anywhere near as smooth as some of the aftermarket shocks we've been testing.
Ride and handling seem the same otherwise.
I'll be riding some more next week, so may have additional impressions.
After the ride, we commenced to taking a closer look at the M8 engine.
Here are some hightlights-
To change the inside two spark plugs, the tank must be removed and a special set of pliers used to remove the plug wire from the spark plug.
The filter element is tiny for such a large air box.
HD is still using breather bolts and hoses to feed the blow-by into the filter element. The actual breather bolts are the exact same part # as what is in the Twin Cam, BUT, they are further toward the center of the rocker box.
They beefed up the trans shift arm.
This photo shows the 4 (four) spark plug wires coming out of the coil behind the rear cylinder. It also shows the oil return line for the oil that is used to cool the heads.
I did not get a pic of it, but the knock retard is not longer controlled via the ION sensing system via the plug wires. There are actual knock sensors in the cylinders.
Should work much better.
The liquid cooling on the Twin-Cooled engine still works the same.
On the non-Twin Cooled, there is an oil passage in the heads. Oil from the oil cooler is pumped to a splitter on top of the front rocker box. See pic below-
It then travels thru tubes, into the heads and runs between the two exhaust valves on each cylinder, circles around one of the exhaust valves and then exits out of the heads and into tubes that carry it to a single hose behind the rear cylinder. That single hose then routes the heated up oil into the oil tank. See pic below.
The oil cooler is larger than previous years, and looks pretty vulnerable to me. This bike with less than 50 miles on it already has a good sized ding in the fins.
This does not look or feel like a re-worked Twin Cam or Evo.
I just hope that it is well made, because it appears to be a giant step forward for HD powerplants!
I'm really looking forward to doing a Performance Plus Stage I on an M8. I think there is a lot more potential to "wake it up" than the Twin Cams have!
