wheel falls off ? ? ? ?
Aug 18, 2015
312
101
Nv.
Had a friend send this to me. ( I have never heard of this before)
I found this on the Road King Riders Delphi forum.
On Monday, a good friend was killed when one of the rear wheels on his tri-glide detached from the rear end. The trike crashed and he died several hours later in a hospital. Having investigated many mechanical failures as an engineer, I am frequently in search why failures occur. Someone at the memorial service showed me an email where it was written that these trikes have a problem with the left wheel coming loose and falling off. Supposedly, the motor company recommends retorquing wheels every 500 to 1000 miles and it is a known problem with these machines. I accepted this as true at the time. However, I came home and have not been able to find anything about this issue on the internet. Does anyone know anything about this problem? Initially, I assumed it was a maintenance problem, ie someone failed to properly mount the wheel.
On all aluminum wheels, on all vehicles you need to re-torque the wheels to specs after they have been loosened & tightened. There have been a few people loose the left wheel, or come close to loosing it but caught the loose wheel before it came off.
On the TriGlide 90ft lbs-100ft lbs torque, then at about 100 miles re-torque to specs & you won't have problems. Or none I have heard of.
But this procedure goes for any aluminum wheel. On any vehicle.
To me this is something else to consider when deciding to let a dealership do all your maintenance, part of your maintenance, or none of it.
Checking the rear lugs for proper torque is probably a listed item a dealer would do at the 1,000 mile service. So would you trust them to actually do it, or are you better off doing it yourself?
To me this is something else to consider when deciding to let a dealership do all your maintenance, part of your maintenance, or none of it. Checking the rear lugs for proper torque is probably a listed item a dealer would do at the 1,000 mile service. So would you trust them to actually do it, or are you better off doing it yourself?
You are better off doing it yourself, if you do it properly and IF you do it.
I believe Keystone, a moderator here, had one of his rear wheels come off his Tri-Glide while riding it...this was a few years back. I'm sure he'll correct me if I am mis-remembering.
I NEVER trust the dealer to torque them down correctly.
I always retorque mine after 50 miles....I think the manual says after 100 miles.
I also check them periodically. Just did it yesterday morning before leaving on our trip.
I might know a thing or two about that....
It's not a Harley issue as in the MoCo. This happens to cars/trucks too. If they are not properly torqued they can come off anywhere from a few miles to 1k miles later. This happened to me 6 years ago. That dealership hasn't received any business from us since.
I do my own
I have had the wheels off our Trike several times and have had no problems. If you have any thoughts or even think something doesn't feel right or sound right riding you got to check. Alum. wheels squeak at low speeds when loose, Years ago I ruined a Classic M/T wheel and I heard it squeak my fault. Sorry to hear someone lost their life. ride safely Fred
I always have checked my tire pressure and torqued the lug nuts before any ride....long or short. You can loose a pound of air every month so good idea a check pressure monthly .
8~\o
I always have checked my tire pressure and torqued the lug nuts before any ride....long or short. You can loose a pound of air every month so good idea a check pressure monthly . 8~\o
I am going on a long ride from DFW to Grand Canyon on back in a few weeks. I will probably not carry the torque wrendch, but I will carry the lug wrench and check at end of each full day.
Thanks for posting. I checked mine after reading this. Dealer did a 1,000 service the middle of April and I've put 3k on it since then. I just had the dealer do a full fluid change and ask them to check it over good. My left lug nuts were not 90 lbs, but probably higher than 80. Right lugs were all good except 1 that was close.
I ran into this problem years ago, Aluminum wheels after time start to corrode, when removing wheel for what ever reason there is always aluminum corrosion on the steel mounting surface mostly in the center hub area, if you don't clean this white powder/corrosion and just remount and torque the wheel, this corrosion breaks up and now you have the start of a loose wheel, re torquing will help, but cleaning the corrosion will solve the main problem before installing the wheel. I ran into this problem with Ford SUV's. But any Aluminum mounted to steel will cause this corrosion.
8~\o
+1 Got to pay attention I just checked mine 10 minutes ago. Easy to do expensive to ignore Torque and air pressure. good reminder for everyone. I trust no one with my safety and equipment. :skull: travel safely Fred
100 lbs
Ok, So whats the setting :Shrug: 80 or 100 ft lb :Shrug: for a TriGlide
I set mine at 100 lbs and check them a couple of times during the riding season.
Last summer we went on a 3000 mile ride and when I got back the left wheel had a couple down to 90 lbs.
Rode the rest of the summer and when I checked them this spring they were all at 100 lbs (give or take a few lbs).
I always check mine before a long ride and then again when I get back. I think if you set them at 100 lbs to start with you should be good to go for most of the main northern riding season unless, of course, you put on a bazillion miles!
This post couldn't have come at a better time.I normally check after 100 miles if I have the wheels off,But since reading this post i will pack a 3/4 socket,extension and a torque wrench on longer rides.Leaving in the morning to Ohio bike week in Sandusky. So I added a couple of items to the trunk.
​WOW, this is a great heads-up and a darned shame it has to come at the expense of someones life. I had no idea this was a problem with aluminum wheels as I've had several sets on cars over the years. But wrote a note to retorque ours in the AM.
PC
tw0fast4u
tw0fast4u
