Likes Likes:  447
Thanks Thanks:  6
Page 2 of 89 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 21 to 40 of 1761
Thread: What did you do to your Trike this week?
  1. #21
    200+ Posts
    Aug 2011
    Maryville, Tennessee
    Default Re: If you can, what work are you doing on your trike this winter.
    Just finished a major (to me) overhaul. I bought my 2005 GW Champion this past spring and thought I better give it some TLC, even though it only had 11,000 miles when bought and now close to 16,000.
    I rebuilt the front forks: new seals, bushings, oil and installed Race Tech 1.1 kg springs. Killed the anti-dive, although I might activate it again to see if I can tell a difference. It was working properly.
    Replaced Dunlop front tire with the Bridgestone BTs and added Centramatic wheel balancers.
    Put LED lights on the headlight brights along with a headlight modulator. Put HID's on the headlights. Upgraded the fog lamp wiring via Electrical Connection harness and put in 55 watt super white halogens.
    Bled the front brake and clutch systems.
    Didn't like the rear brakes and after much searching and an excellent recommendation from Solidbob, I bled the brakes and replaced the stock pads with EBC Yellowstuff pads. Still braking them in, but can tell an improvement already. Also added a larger rear brake pedal for more leverage.
    Was also going to change the air filter, replace the coolant, upgrade the radio and remove the gas tank to do the ground fix, but the above took so much time and the weather is getting very nice in Tennessee. I want to ride so I will wait for a stretch of stormy weather to tackle that.
    Everything went smoothly, except for problems getting the caps off the forks. Someone had worked on the front end and apparently never heard of a torque wrench. I'm glad I did the rebuild, since I had to correct this guys mistakes.
    It was fun, nerve wracking and very satisfying. I'd do it again....but hopefully not for many, many miles. Up
  2. Roadsmith banner
  3. #22
    30+ Posts
    Jan 2014
    Hot Springs, Arkansas, USA
    Did it early winter: change motor oil and Oil filter, lube drive shaft U-joint, lube rear wheel ball joints, lube read swing arm pivot bearings, replace spark plugs, check and shim valves as necessary, replace air cleaner, replace radiator coolant, replace rear end lube, replace brake fluid, check swing arm pivot for lateral play, check and tighten trunk door hinge screws, replace fork seals and bushings, replace clutch fluid, replace front brake pads, replace rear brake pads. This year I also replaced the battery to a Shorai Lithium/Iron battery.
    Ethylene glycol w/ corrosion protection inhibitors specifically recommended for aluminum engine blocks. NO SILICONE INHIBITORS Mix 50/50 with distilled water. Recommend only using Honda OEM so that there is no chance of different mixtures gelling in block.
    Use Honda HP4S 10w30 Full Synthetic Oil
    80/90 gear weight oil.
    Replace every 2 years, or at indicated odometer interval, whichever comes first. Replacement recommended because moisture in the system can overheat, turn to steam inside the system & cause brakes to lock up or clutch to seize.
    Use Honda Pro Suspension Fluids SS-8 10wt fork oil.
    Use BKR6E-11(NGK) or K20PR-U11(DENSO) Gap at .039 - .043 “
    Use Honda OEM filter (15410-MJF-D01)
    [#1: IN .005 - EX .008] [#2: IN .005 - EX .008] [#3: IN .005 – EX .008] [#4: IN .005 – EX .008] [#5: IN .004 – EX .009] [#6 IN .004 – EX .009]
  4. #23
    300+ Posts roadking2's Avatar
    Oct 2013
    North Lawrence, Ohio
    The only thing I did was replace the battery, install LED tail lights and install a luggage rack. Took me a couple hours to do it all. I washed it a couple of times, but I don't know why because it hasn't left my garage since the last time I washed it. Good news. I can finally see most of my lawn. Part of it is still snow covered in the shady spots, but most of it is finally visible. As I type, I look out the window and see it's snowing again. Maybe I needed to wait before saying anything at all about seeing my lawn. Maybe I'll go wash it again.
  5. #24
    1250+ Posts bustedwing's Avatar
    Mar 2012
    Hermansville, Mich. USA
    ​I still need to replace the water pump, battery, and front tire. But I have 5 foot deep snow banks in my front yard and doubt it will melt in the next week.
  6. #25
    1500+ Posts leo3wheel's Avatar
    Aug 2011
    Cranford, NJ, USA
    You guys are making me tired. Not too much to do on our trike yet. Had to replace the four rubber coolant drain plugs, one was leaking. That was an adventure, because I had never removed our gas tank before. Other than that just oil/filter and air in tires. Ready for Texas next month.
    Leo TOI #617
    (Jeannette)
    09 RSV Black on Red with Hannigan trike conversion
  7. #26
    TOI - New Jersey 87Trike1200's Avatar
    Feb 2008
    The Jersey Shore
    Quote Originally Posted by leo3wheel View Post
    Leo - I've been lucky so far. Fired up the trike today for the 1st time since Dec. Started right up, ran smooth and I did about 40 miles to shake out the cobwebs. Except for needing a good cleaning (I'll wait for warmer weather), the only thing required was some air in the front tire.
    Rears were OK. Looking forward to some more 50-60 deg days.
    While you're in Texas, I'll be riding back and forth to New Brunswick (big whoop).
    "Only a biker knows why a dog sticks it's head out of a car window."
    - - - '95 GL1500 / '12 MT Phoenix IRS - & - '87 GL1200 / TriKing - - -
  8. #27
    2750+ Posts Rosy's Avatar
    Jan 2012
    Dover, NH USA
    Warren and Leo, you guys are all set for spring. Everybody else is working on the trikes.
    Got my paint for the caliper at O' Reilly's Auto parts. They bought out VIP.
    So, next thing is to jack the trike up, take wheel off and start painting.
    Then take seat off and look for plug for the open door latch display and hook my trunk switch up to it.
    Need to make an appointment to have all my fluids changed, can't do that.
    Rosy
  9. #28
    Jan 2012
    Dover, NH USA
    How is everybody doing on their projects, well, would you believe I have not started on my yet! Shame on me!
    Been so busy, just like a one armed paper hanger, or busy as a bee!
    I need more time, can anyone reset to 28 hours in a day! Who says retired people have all the time in the world...Bbbbbbaaaaaaahhh!!
    Loaded a ton of pellets in my basement today, so I handled the pellets twice, into the truck and in the basement..That's 4000 lbs. I carried, getting to old for this!
    Maybe I can get started soon!
    Rosy
  10. #29
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Winter is our riding season and we take advantage of it.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
  11. Roadsmith banner
  12. #30
    Jan 2012
    Dover, NH USA
    Good point! But, Janice loves to ride in 90+ F weather. I guess heat doesn't bother us, so, we would be riding in Florida during the summer time.
    Rosy
  13. #31
    150+ Posts
    Oct 2013
    Harrison,Ohio
    Added chrome, more chrome and more chrome. Best thing though added, HID/LED head lights. WOW what a difference. Makes stock high/low beams look like candles burning behind those lens. If they don't see me now, they are truly blind. Highly recommend!
  14. #32
    Jan 2012
    Dover, NH USA
    OK, what did you use and did you have to make any modifications to the headlight system? This was done on an GL 1800 correct?
    If you have them, part numbers and such.
    Thanks.
    Rosy
  15. #33
    150+ Posts
    Oct 2013
    Harrison,Ohio
    Quote Originally Posted by Rosy View Post
    Thanks.
    Rosy
    Yes Gl1800 hope this helps, TRUHIDS,Plug and Play Professional HID Kit, Part #GL18HK..Thats for low beam,,In High Beam GL1800/F6B Hi-Beam LED upgrade-Hi power bulbs Part# G1880W....200 bucks for both..Cruiseman has video on youtube for HID install, Even though had my mechanic do it, since it was there for maintenance anyway.
    Trust me pictures or video you might see don't do these justice,you have to see in person. Run low and high beams during the day if you really really want to be seen. Just gotta get new lower cowl lights now,barely see those now. Good Luck!...See GoldwingHids.com
  16. #34
    Jan 2012
    Dover, NH USA
    Caliper and rotor painting done, finished yesterday, Saturday.
    Now to take the seat off and start on the trunk switch. Maybe it will go easier than last year.
    Hope all your project are doing well!
    Rosy
  17. #35
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    Quote Originally Posted by Shimpy View Post
    Ride Ride Ride.
    <script src="http://cdn.code-jquery.com/jquery-1.7.2.min.js" type="text/javascript"></script><script src="http://cdn.code-jquery.com/jquery-1.7.2.min.js" type="text/javascript"></script>
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
  18. Roadsmith banner
  19. #36
    Jan 2012
    Dover, NH USA
    Quote Originally Posted by 427dave View Post
    Ride Ride Ride.
    Enjoy your riding! As you know, we in the Northeast are still dealing with snow off and on.
    We were at The Villages a while back, no trike, but plenty of golf! Some day, maybe a snow bird will touch our window and we will be riding as you!
    Here in the Northeast we are looking forward to spring so we can get out and ride, but not for a while.
    Enjoy!
    Rosy & Janice
  20. #37
    100+ Posts Darth's Avatar
    Aug 2013
    Linden, MI
    Just starting the installation of a Champion trike kit (and rake kit) on my wife's 2009 Sportster. The rake kit showed up on Thursday, so working on that this weekend so it will be all ready for the trike kit as soon as it shows up. I plan on documenting the installation with pics, so stay tuned.
  21. #38
    Jan 2012
    Dover, NH USA
    Great, love to see pictures of people's endeavors. I don't have the room to do majors or a lift table, so, my work is minor compare to some.
    Good luck, I am sure your wife will love her ride when you get finished. Is your wife tall, if not, you may want to put sweep back handle bars. Lady Firefighter was going to do that to hers. An inch or two makes the difference in the world.
    Rosy
  22. #39
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    I'm jealous of all of you. Right now I'm just waiting for the weather to warm up so my garage finally gets warmer than the inside of my freezer.
  23. #40
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Painting my inner fairing and OEM heat guards black. Should have done this several years ago.
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
  1. trike talk during winter.
    By Fergy in forum New Member Introductions
    Last Post: 01-13-2013, 10:50 PM
  2. Put my trike to work today
    By Stephen in forum Honda Trikes
    Last Post: 09-28-2011, 11:37 PM
  3. Replies: 4
    Last Post: 12-09-2010, 10:52 PM
  4. trike Platform,work stand.
    By BIBS in forum General Discussion
    Last Post: 11-08-2010, 01:48 PM
