Likes Likes:  65
Thanks Thanks:  2
Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 21 to 40 of 186
Thread: Aftermarket Exhaust on new Triglide
  1. #21
    300+ Posts
    Oct 2012
    Marietta Ga.
    Default Re: Aftermarket Exhaust on new Triglide
    Wow!...I got to thank Rhino and Msocko3, I had no idea that the stock mufflers were different, and I was getting ready tomorrow to put the stock ones back on, one reason is there is a steep hill on the way home, I noticed when I had the stock mufflers on and in 3rd gear at about 3500rpm and goose it, it seemed to have a lot more power then the day I went with the Rush slipons .
    My problem now is I forgot which muffler was left or right , I looked at the part #'s on them, one is 65538-09 and one is 65846-10A any one know which is right or left ?
    Thanks again for the info. I was just getting ready to screw up .
    I've suffered a great many catastrophes in my life....
    most of them never happened.;)
  2. #22
    Quote Originally Posted by lboos View Post
    Just run a stick up the mufflers, The stick will only go in a few inches on the left, while it will go in about a foot on the right one..
  3. #23
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    65846-10A is the right and 65538-09 is left. Exhaust can make or break how a bike or trike performs. To large of a baffle with a stock or mildly modified engine will kill the bottom end, like wise to small of a baffle with a large displacement high performance build will kill the top end, but it can also help build some more bottom end torque.
  4. #24
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Too %$#@ much trouble, do this/do that/can't do this/can't do that/must do that/must do this/is it legal/is it illegal - I'm sticking with the stock pipes. Never had a problem performance wise or sound wise with them. I think the pipes on the '14's are the best sounding stock pipes on any bike.
    Go ahead and spend hundreeds of dollars if you want - not me. Like JJTriker said leaves more money for more important things.
  5. #25
    2250+ Posts
    Ocala, Florida
    GaryD said it best, sound will be the easiest 'crime' for the politicians to identify and they'll come after us like crazy. We'll lose that contest simply because we'll be out voted by the non-riders. He's also right about those with loud pipes just needing to be noticed. If we don't regulate ourselves, the man will regualte us instead.
    Before I bought my last set of pipes I spoke to several manufacturers and they all told me the same thing: to get the deepest sound, look for the largest diameter muffler (canister) the manufacturer makes. The largest canister has the best opportunity of attenuating all the high frequencies tones we don't want, to get the deep rumble we do want.
    If you find someone that has mufflers you think you might like, standing behind them and blipping the throttle is OK, but not as good as having them go thru the gears riding away from you. Hearing the engine under load is more definative than just revving it.
    Ain't muffler hunting fun! I went with Vance and Hines Monster Rounds.
    Phu Cat (II Corp, Binh Dinh, Arizona)
  7. #26
    100+ Posts hdruss's Avatar
    Mar 2011
    chicago,illinois
    BEER!!
    Black '19 FLRT , Detachable Bat Wing Fairing
    '82 FXR Being Triked
    TOI #01075, ABATE of IL. & MI., BTW, HOG
  8. #27
    150+ Posts greyfang's Avatar
    Nov 2010
    Loveland, Colorado
    I went with the entire setup from Fuel Moto. Ceramic head pipe, tuned mufflers, stage one air and a pre mapped tuner. Reason was not primarily for the sound but a cooler running engine and a little more power. The sound is just a bit louder than stock but far from being obnoxious IMO. Super loud pipes are not for me.
  9. #28
    20+ Posts Vict-0's Avatar
    Nov 2013
    levittown
    i have a 2014 triglide with V & H true duels, screaming Eagle stage one tune and air cleaner. pipes are definitely louder, but can be easily controlled by the throttle. Cruise speed is no problem with noise. i have, however noted that before the upgrade, the intake was extremely noisy, but not as much after.i was concerned about the heat, which was a little noticeable after getting warmed up.
    The other issue was the amount of power at highway speeds when passing. she was little slower then my ultra, i guess because of the weight. we have been working on the tune, and the increase in power and torque has been impressive. looking to straighten out a flat spot between 2500 to 3000 rpm. above 3300 it wants to jump down the road. heat is good. had a friend ride the bike away from me and it has a great Harley sound.
  10. #29
    300+ Posts
    Dec 2011
    Iowa
    Quote Originally Posted by greyfang View Post
    Same setup on my 2011. Nice sound and the map they sent works great.
  11. #30
    Mar 2013
    here
    Don't like riding with loud pipes anymore. No mater how loud I have made my newer bikes, it never sounded like my 84 shovel.
  12. #31
    GLEN ELLYN, IL. USA
    Last weekend I went for the longest ride so for with the new TG. About half wat to my destination I was a little annoyed with the stock exhaust - it was a bit too loud - nice deep rumble, but too loud - for me anyway. Can't imagine someone actually wanting to make it louder especially for long rides. I will be wearing EAR plugs on my trip to Rolling Thunder next week.
    Do they make quieter pipes???
    Heat wasn't a problem either and I have enough power to do anything I want to do - legally or illegally - so as hdruss correctly said leaves more money for more important things = BEER and pizza.
  13. #32
    200+ Posts sprinkman's Avatar
    Sep 2011
    Ashland,Ohio USA
    I have 4" SE slip ons on mine they have a nice sound not to loud. They will rumble if you give it the throttle. Have had stock, V&H slash cuts, and Bub 7 on it I like the SE the best.
  14. #33
    Sep 2009
    NE Ohio
    I see they made a change in the right side muffler for the 2013 MY, maybe they tweaked it to make it a touch louder due to the cat acting like a pre-muffler.
  15. #34
    GLEN ELLYN, IL. USA
    Quote Originally Posted by msocko3 View Post
    You could be right. All I know is it's a bit louder then any of my previous bikes.
  16. #35
    750+ Posts tom w's Avatar
    Sep 2013
    poplar bluff mo
    had drag pipes on my 1200 sportster (no baffles) Great performance!. I don't think you can get any louder. at least I cant hear it any more if you can.
  17. DKCustoms postbit
  18. #36
    20+ Posts
    Feb 2013
    canada
    Just got a 2013 Triglide. For a 103, I found the power a little I expected much more. So .... I will make more. Those that say their trike is peppy just don't know performance. Sure I know there is more mass to get moving. I'm just saying that a machine of this caliber should get more out of a 103 cu. in. motor.\
    Thats 1690 cc.
    One of the biggest bike motors out there.
    I believe its pollution restrictions that can be blamed for a motor that can't breath. I had a 2001 classic with a 95 inch build that got 50 miles per gallon two up riding. No BS, I checked.
    That's Canadian gallons which are 1/5 bigger than the US gallon. It dyno'd at 108 hp 104 hp. Very reliable. Lots of pep. Even loaded down with two up and camping gear. Now I got a trike with a 103 and I feel its a slug. So here I go again with performance changes to suit me.
    And I'm only 66.
    SO ... to those that may know.
    Can I leave the stock pipes, change the air cleaner and add a cam, or do the pipes have to go.?
  19. #37
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Just got a 2013 Triglide. For a 103, I found the power a little sucky. I expected much more. So .... I will make more. Those that say their trike is peppy just don't know performance. Sure I know there is more mass to get moving. I'm just saying that a machine of this caliber should get more out of a 103 cu. in. motor.
    Thats 1690 cc.
    And I'm only 66.
    Can I leave the stock pipes, change the air cleaner and add a cam, or do the pipes have to go.You can leave the stock pipes, but if you do a free flowing A/C, a good tune, and cams, you will be leaving a lot on the table if you don't replace the restrictive exhaust also.
    www.DKCustom.com
  20. #38
    70+ Posts bulkness's Avatar
    Apr 2012
    Kamiah, ID, United States
    I took my stock 2014 mufflers off today and I was really surprised in how restricted the flow is. There is an almost closed restriction about 3/4 the way down both mufflers. No wonder these Tri-Glides are so warm. Tony
    2014 Harley-Davidson Tri-Glide Blue/Black
    tGlide 1.25 Lift Kit, tGlide Tour Box Lift, H-D CB, H-D Chrome Bumper, Moore Sensible Products Remote Oil Filter Kit, FullSac DX Header, Rush Big Louie Mufflers, Screamin' Eagle High Capacity Oil Pan
  21. #39
    500+ Posts WindyOne's Avatar
    Dec 2009
    Va.
    I know this thread is gaining age but I wanted to add what I found on my stock mufflers. I can stick a piece of wood about 10" in the end of either muffler. Running a light in the end it looks like the baffle closes up on 4 points blocking the air flow. This is on a 2013 stock mufflers both sides
  22. #40
    On my 11 Tri-Glide the stock left side muffler in baffled down at least 30% more than the right side, And thats so the back pressure will be even with both cylinders, So if you go to true duels, You can't/shouldn't use them it defeats the purpose of the true duels.
  1. Who makes the best aftermarket exhaust for GL1800?
    By mpolissky in forum Honda Trikes
    Last Post: 11-24-2014, 05:57 PM
  2. stallion aftermarket headlights?
    By 281stallion in forum Stallion Trikes
    Last Post: 06-24-2013, 11:15 PM
  3. Aftermarket cruise control
    By jaxbobg in forum Accessories
    Last Post: 07-07-2012, 08:33 PM
  4. GPS/CD/Audio Aftermarket.
    By Guido Gonzeaux in forum Harley Tri Glide
    Last Post: 05-17-2011, 10:20 PM
  5. Changes to the Stallion or New Aftermarket Parts?
    By Mattel in forum Stallion Trikes
    Last Post: 10-26-2008, 08:06 PM
