Like the title says gear ratio for 88 goldwing 1500 interstate because I am triking it and using a 7.5 ford rear end so I will need to know what gears to use and tire size if anyone can help me. And is there a formula to figure this our?
If I had a manual or could get a decent one I wouldn't be asking and I was asking to see if anyone else has used the 7.5 ford rear and pick their brain on rearend gears and tire size to try. But thanks for your reply.
Dcryder, My gl1100 homebuilt trike has the 7.5 Mustang rear end with disc brakes. I started out with a 2.73 ratio, On takeoff the high gear just did not have enough get go, Well I changed it to a 3.43, Well that was way to low,5grand at 60 mph,[I had this in stock]. I finally went with a 3.08 and am very happy with it. just my 2 cents worth. CharlieLike the title says gear ratio for 88 goldwing 1500 interstate because I am triking it and using a 7.5 ford rear end so I will need to know what gears to use and tire size if anyone can help me. And is there a formula to figure this our?
