Likes Likes:  700
Thanks Thanks:  56
Page 3 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 41 to 60 of 651
Thread: 88 blazer trike
  1. #41
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default reply to thread
    fowler...one idea is to ditch the serpentine.....get a v-belt style waterpump (should turn opposite direction) ,crank pulley and alt/w/v pulley and mount the alt down where the ps.was?? larry
  2. #42
    May 2014
    Wisconsin
    What are your plans for suspension? Stock leaf springs, or coil springs? Is the motor going to be behind the seats? I have a 2000 s10 I can get for free and want to build a trike out of it, but it has a 4 cylinder and a 5 spd. I would have to ditch the tranny. I would love to hear more about your plans.
  3. #43
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Quote Originally Posted by LarryA View Post
    I was doing some research on this and not sure I like the idea of mounting the Alt that low. But thanks for the suggestion
    Thank you
    Bob
  4. #44
    Sep 2014
    Moneta VA
    Quote Originally Posted by BIGJEEPMAN View Post
    I plan to go with coil over shocks with a Tringulated 4 link.
    The engine will mount up front and I will straddle the transmission
    I should be removing the body sometime soon. It is ready to come off I just need a friend to come take it.
    I think the Transmission is a 700r4 and it is 4x4. I am hoping to trade it along with the transfer for a 2WD transmission.
    I will not know for sure until I get the body off but I believe I will narrow the rear axle and frame.
    The front part of the frame where the engine mounts I will remove and build my own then tie it into the narrowed original rear frame
    BUT I will not know for sure on anything until I get the body off. I hope my friend come to get it soon.
    Thank you
    Bob
  5. #45
    Jun 2016
    milnor n.d. usa
    fowler...hope your friend is storing the body...wiring harness, computer etc. will require you to visit the body more times than you would think!! my2c. sounds like you have the plan coming together. i'm going to enjoy the build!! larry
  6. #46
    Sep 2014
    Moneta VA
    I have pulled everything I can think I need off the body. Even the ECU.
    I hope I did not forget something but if I did I will have to deal with it.
    I was planning to buy a stripped down/custom harness or build one if I have to.
    My friend is supposed to come get the body next weekend.
    I priced some of the steel I need and its cheaper than I remember from my last build.
    I will at least be building the front part of the frame (where the engine mounts) and may just build the entire thing. Have not decided yet. Need to see the blazers frame first.
    I figure I will use 2x2x3/16 for any frame parts I build.
    Going out to work on my dog now. I have to figure out how to make the skull
    Thank you
    Bob
  7. #47
    Jun 2016
    milnor n.d. usa
    Default the dog
    fowler... keep us up on the dog build!! as well as the trike......very interesting combination!!
  8. #48
    70+ Posts BMB Guns's Avatar
    Dec 2015
    Louisiana
    Keep the updates and pics coming! This forum has been a big help to me with my build. I'll keep checking in to see how you are coming along.
    The Warrior of the Wasteland! The Ayatollah of Rock and Rolla!... FYI: My 12 year old daughter drew my Ghost Rider on a trike Avatar for me! She's so talented!
  9. #49
    Sep 2014
    Moneta VA
    My friend is promising to come get the body tomorrow after work.
    I pick up the steel Friday going with 2 x 2 x 3/16
    I am thinking of making a wooden engine/trany cradle on wheels. It will sit at the height and angle I want the engine and Trany to be on the trike. This way I can build my front frame and engine mounts around it.
    I have not down it like this before but in my mind it sounds like it will work
    Thank you
    Bob
  10. #50
    Dec 2015
    Louisiana
    Quote Originally Posted by Fowler View Post
    That sounds like a good strategy (making the engine and transmission free standing). I made feet mounted to my engine that allowed me to block the engine up to get it where I needed it in the frame. Working with a heavy engine with heavy transmission bolted to it us both dangerous and potentially costly if it is dropped and parts start getting snapped off! My advice is to build your cart stronger than needed and don't go cheap on the wheels. Get some nice heavy duty wheels. They can always be recycled for future projects.
  11. #51
    100+ Posts
    Feb 2017
    DE
    Default Rear width
    you talked about shortening up rear, did you nail down width of unit?
    I'm def going to shorten mine up still will be wide compared to some.
  12. #52
    Dec 2015
    Louisiana
    Everyone is cutting width on their rear end and I'm over here going full retard. ..
    Name:  2017-02-01 18.13.10.jpg
  13. #53
    Sep 2014
    Moneta VA
    Quote Originally Posted by TwistedKarma View Post
    I am waiting to get the body off the donor vehicle first. It should be coming off tonight
    Once it is off can take better measurements and make a decision
    I did some research and found trikes from 60" to 75" and even 1 or 2 80" or more
    I believe the Blazer (the Donor vehicle) is 64"
    Thank you
    Bob
  14. #54
    Sep 2014
    Moneta VA
    Quote Originally Posted by BMB Guns View Post
    That's a Beast
    Thank you
    Bob
  15. #55
    Sep 2014
    Moneta VA
    I finally got the body removed
    Now I am working on striping it down
    Thank you
    Bob
  16. #56
    Meme Master
    Jan 2014
    Farmington, NH USA
    Why not do an all wheel drive, or front wheel drive "reverse" trike?
    Might be easier than you think, & definitely 1 of a kind...
  17. #57
    Sep 2014
    Moneta VA
    That sounds like a cool idea but I have pictures in my head basically how it will look
    Some things I am debating with myself are
    How wide the rear frame and axle will be
    . From the outside of 1 tire to the outside of the other is 63.5". From what I have read that's not bad
    Normal size tires or wide tires. whats to Pros and Cons of each. I have not researched this yet
    Engine/trany height and Pinion angle
    I have been doing a lot of reading on this lately.
    Where to place the seats Got to figure this out sooner then later. It will factor in in the frame design (mainly length)
    where I will tie the new front frame to the old rear frame Or do I just build a completely new frame. I have been researching both, I have been mainly looking at Hot Rods And Trikes but been getting ideas from a lot of areas
    Almost positive It will have a coil over. But have seen some real neat ideas with the leaf springs. Moving them inside or making a Transverse one
    Link design
    I have been researching this a lot also Thinking of a Triangulated 4 link
    there's a lot more running through my head but will deal with them in time
    Thank you
    Bob
  18. #58
    Sep 2014
    Moneta VA
    all stripped down ready ready to pull the engine/trany.
    Still have not decided on the rear end yet. I really like the look of the leaf springs but they are so stiff
Size:  585.5 KBName:  2.JPG
    Thank you
    Bob
  19. #59
    Sep 2014
    Moneta VA
    Next steps in order
    1. pull engine/trany
    2. build stand and place engine and trany on stand
    3. correct pinion angle on rear end with shims
    4. Weld in cross member just in front of forward leaf spring mount
    5. Cut old frame just in front of new Cross member
    6. Build front frame and engine mounts
    7. Attach front frame to new cross member
    I think doing it this way I still give myself the option of using either Coil overs or Leafs. I like the look of the leaf springs but they are stiff. I can take out a leaf or 2 to see how that works but I just dont know. I have read that coil overs with a 4 link are a better ride
    Also doing it this way still gives me the option to build the rest of the frame and narrow it if I decide to do that.
    I do not want to limit my options just yet
    Now that I think about it maybe # 3 (pinion angle) should be last
    Thank you
    Bob
  20. #60
    Jun 2016
    milnor n.d. usa
    fowler.. 2 factors that I see....#1 is pinion snout twisting up under acceleration.#2 is just hitting a bump ie raising the whole rear end straight up with no twist... leafs with a snubber for the snout will work just fine.....the 4 link takes care of the wrap up by virtue of it's design also. either way, the mounting should be adjustable to fine tune. anyhow, this thinking and figuring was the favorite part of my build....I did it leaning back in my chair with my feet up!! larry
  1. Happy Birthday Trail Blazer
    By Papa Zook in forum General Discussion
    Last Post: 12-07-2016, 02:39 PM
