Likes Likes:  4
Results 1 to 13 of 13
Thread: license plate relocating
    20+ Posts
    Sep 2015
    snow hill
    Default license plate relocating
    have a 2015 freewheeler with a bumper on the rear. i want to move my license plate from the left side to the center of the trunk area. any ideas on doing this? either on the bumper or the trunk. help will be much appreciated.............
    Jun 2010
    Coram, NY USA
    Duct tape?
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Quote Originally Posted by Bikerbozo View Post
    Duct tape?
    Clown!!! LOL
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    70+ Posts slaw32's Avatar
    Jan 2016
    S e south dakota
    Default Like this?
    Check with Kevin at D K . Attached to trunk , DK has a led license plate light , I mounted above plate holder .
    Jan 2016
    S e south dakota
    Oops!! Wrong file , Daytona bike week .
    20+ Posts
    Sep 2015
    snow hill
    Default brilliant thought
    Duct tape?
    ?? thanks bozo, took awhile to think of that i guess??
    20+ Posts
    Sep 2015
    snow hill
    Default thanks
    will look into that,thanks alot slawName:  rps20170528_064648.jpg
    Check with Kevin at D K . Attached to trunk , DK has a led license plate light , I mounted above plate holder .[/QUOTE]
    20+ Posts
    Sep 2015
    snow hill
    Default great
    Quote Originally Posted by LadyonaMission View Post
    great response appreciate it.......
    20+ Posts ronc4424's Avatar
    Jan 2010
    Danvers,Ma & Ashland NH
    Default Relocated Plate
    Name:  20170223_104717 (2) (1024x768).jpg
Size:  405.3 KBName:  20170301_135155 (2) (1024x768).jpg
    Here's a before & after of mine. I mounted a pc of alum 1"x 1" angle the length of my plate under my bumper using 3M two sided automotive tape. I then pop riveted 3 alum 3/8 rivets for a tight & secure install.I drilled holes in the bracket for the plate and frame before I mounted it. To light the plate I installed Custom Dynamic white tag LEDS, part # TBO1C.....$19.95 pr. I ran the wiring under the body to under the seat and tapped into the right side tailight. Good Luck!
    [/SIGPIC]paddle faster, I think I here banjos
    20+ Posts
    Sep 2015
    snow hill
    Default thanks
    thank you,nice post
    Here's a before & after of mine. I mounted a pc of alum 1"x 1" angle the length of my plate under my bumper using 3M two sided automotive tape. I then pop riveted 3 alum 3/8 rivets for a tight & secure install.I drilled holes in the bracket for the plate and frame before I mounted it. To light the plate I installed Custom Dynamic white tag LEDS, part # TBO1C.....$19.95 pr. I ran the wiring under the body to under the seat and tapped into the right side tailight. Good Luck![/QUOTE]
    Default Question
    What lights you got on the back of your trike?
    Quote Originally Posted by Silverfox77 View Post
    Chris welcome to Trike Talk…on your first post… and just a heads up the post you were referring to is from 2017… Hopefully you’ll get an answer..?
  1. License Plate Bulbs
    By 470004 in forum Harley Tri Glide
    Last Post: 05-27-2016, 10:48 PM
  2. License plate bulb
    By Just...Chuck in forum Stallion Trikes
    Last Post: 09-17-2014, 01:32 PM
  3. License Plate Frame
    By jimdog1356 in forum Harley Trike Conversions
    Last Post: 03-08-2012, 02:40 PM
  4. License Plate Mounting...
    By Mirth in forum Harley Trike Conversions
    Last Post: 07-08-2010, 08:09 PM
  5. Mounting License Plate
    By CRBandit in forum Stallion Trikes
    Last Post: 09-06-2009, 02:56 PM
