Likes Likes:  76
Thanks Thanks:  12
Page 6 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 101 to 120 of 263
Thread: Lehman Trike Parts & Info Thread
  1. #101
    Aug 2017
    stevensville, mt, usa
    Default rear u joint
    I have decided to chime in with an announcement. Many Lehman owners are having difficulty contacting the factory to get parts and or part numbers, answer to maintenance questions and general information on their Lehman Trike. Since the company is now under new ownership and many of the old employees have left, there is a lot of information that left as well. Many of the models prior to 2002 are unknown to the existing Lehman company representatives and therefor the understanding of particular parts for these models is also missing.
    I have been a Lehman Dealer since 1998 and have serviced and re-built models that date back to the mid-1980's. I also have a number of wear related new parts for these older dis-continued models as well as part numbers for the ones I don't stock.
    Post a question or comment and I will do my best to solve your issues.
    Jim
  2. #102
    Aug 2017
    Default u joint
    I need a rear u joint and possibly foot pads for a 2006 Suzuki with tramp kit. Any ideas? Thanks, Chuck.
  3. #103
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    I have the U-joint (S002086) and will check for (passenger) foot pads (LP6210 & LP6211) this morning.......
    http://mjtrikes.com/shop/index.php?m...roducts_id=283
    Jim Murphy
    Iron Butt Rider 2001
  4. #104
    Martinsburg, WV
    Quote Originally Posted by cikmontanan View Post
    I have one RIGHT HAND passenger footboard ... NEW ... $65.00
    Jim Murphy
  5. #105
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Jim,
    On the older auto (Ford) differential how often do you change the oil.
    Also what type of oil do you use.
    Thank you in advance.
    Attachment 48835
  6. #106
    Martinsburg, WV
    Quote Originally Posted by Gideon View Post
    Jim,
    Attachment 48835
    It probably wouldn't hurt to change it at 5,000 miles at first. After that, every 40,000 miles.
    Jim Murphy
  7. #107
    Dec 2012
    Thank you for your reply.
    Ride safe
    God Bless
    Bob
  8. #108
    Sep 2017
    Edgerton, WI, USA
    Default 2002 Harley Davidson FLHTC Lehman Trike right side cover.
    I'm looking for a side cover for a 2002 Harley Davidson FLHTC Lehman Trike. Lehman says they don't make them anymore.
  9. #109
    Martinsburg, WV
    Quote Originally Posted by Keetah1 View Post
    Lehman made two different style side covers for the Renegade conversion. There was a 2 piece cover that had a removable front portion on the earlier Renegades and then they used a 1 piece cover (lovingly referred to as Elephant Ear). Later years they used the stock cover. Which side do you need and what kind do you have ???
    Jim Murphy
  10. #110
    Sep 2017
    Pahrump, Nevada, USA
    Question Kawasaki Vulcan Storm 2011
    Hi
    I need an axle bearing for right side axle.
    Do you have those and how much are they?
  11. #111
    Martinsburg, WV
    Quote Originally Posted by JohnnyVegas View Post
    Hi
    Lehman was developing new drive axles and brake systems between 2009 and 2013. The model you have may have had 2 of the 3 styles. If you can attach a picture of the axle housing, or a picture of the axle removed I might be able to help. PM sent
    Jim Murphy
  12. #112
    Martinsburg, WV
    Attachment 49300Attachment 49301
    Jim Murphy
  13. #113
    Martinsburg, WV
    Default Christmas Wheels for your Monarch II
    I have several discontinued front wheels for the Monarch II. These are custom made wheels with different styles.
    Attachment 52429
    9 spoke Grand National Style
    Attachment 52430
    Lehman Signature
    Attachment 52431
    Razor
    Jim Murphy
  14. #114
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Will these wheels interchange with 1500 goldwing
    what is price of 9 spoke Grand National
  15. #115
    Martinsburg, WV
    Quote Originally Posted by trikeman View Post
    Congratulation on the Tee Shirt win !
    The wheel hub (2 piece) would have to be machined to accept your speedometer drive and bearings. The hub might be a couple hundred dollars and would need a donor wheel doing the machining.
    They make a nice dressup kit for the GL1500 front wheel that I have used that closely matches the GN (9 spoke) wheel.
    http://wingstuff.com/products/19-chr...el_accessories
    Jim Murphy
  16. #116
    Oct 2010
    Thanks, not many things in life are FREE!
    Thanks for quick response. Have seen the Lazer Accent Spokes. They look great with Tri Color Ring Of Fire. That sounds like my best option Have a great day
  17. #117
    Martinsburg, WV
    Clean the wheel the best you can before installing the kit. They really do look nice.Attachment 53165
    Jim Murphy
  18. #118
    Oct 2010
  19. #119
    Feb 2018
    Harper
    Default Trying to find parts for Lehman Monarch II
    I've got a 2008 Goldwing 1800 with the Lehman Monarch II trike kit. Any ideas on where to get parts for the rear axle, need park brakes, axle bearings, disc brake pads, and seals.
  20. #120
    Quote Originally Posted by cajunspeed481 View Post
    Welcome to Trike-Talk ...Hill i can't help you on the parts you need, But i'm sure someone will chime in with the help you need.....Again Welcome......
  1. 1994 Genuine Lehman Trike Build
    By Lee H. Mann in forum Trike Builds
    Last Post: 03-15-2022, 06:17 PM
