Likes Likes:  700
Thanks Thanks:  56
Page 10 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 ... LastLast
Results 181 to 200 of 651
Thread: 88 blazer trike
  1. #181
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Quote Originally Posted by LarryA View Post
    I would think it ok. money seems about right.... It's about the same thing I did on Last Winter.....bored for light press on boat trailer bearing races. didn't make any provisions for seals....just made leather washers......turned and threaded a bolt from C1018. Now I'm assuming this is for standard Harley trees and bolt. Is that what front end you are going to use?
    I was reviewing my E bay account and noticed a neck and bearings were ordered.
    I assume my wife ordered a set for me for Christmas (cant let her know I know)
    It does not look like it has seals or is provisioned for seals
    I like your idea of the leather seals
    Tell me more about that
    Also interested in other ideas for seals
    Thank you
    Bob
  2. #182
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default reply
    Bob..... it was maybe 3 yrs.ago, any how I had a boat trailer bearing kit on hand w/ one seal. I couldn't see how I could use the seal with the triple trees bearing directly against the cone. plus I wanted to keep the neck bearing spacing as long as possible. That said, I decided to go with a homemade seal that that was more or less a dust cover. the assembled bearing stood proud out of the neck about the thickness of some leather I had on hand. In retrospect I would probably use some plastic sheet like ice cream pail material......lol....shows you what i know about plastics! Any how the seal id fits around the protuding cone, the od is the same as neck tube dia. Thickness is what ever the clearance is between cone and tree. I greased the leather before installing......I think plastic would be better. Others may have better methods and ways to seal up this area! Good luck Larry
  3. #183
    Sep 2014
    Moneta VA
    I got a idea from reading your post.
    I can make my top and bottom bearing spacers thicker (maybe 1/4 inch)
    So the neck would have 1/4 inch space between the top and bottom and the triple tree
    Then steal the Ol'Lady's cutting board and cut the dust shields out of it.
    Basically the same idea you had with the plastic but a little thicker
    I have used those plastic cutting board for a number of things.
    They are real tough
    what do you think about that idea?
    Thank you
    Bob
  4. #184
    Meme Master
    Jan 2014
    Farmington, NH USA
    Typically, the trip tree & associated bearings, spacers, etc., needs to be assembled to a "tighter" spec than on a 2 wheeler.
    My only concern would be how long a poly or non metallic part would hold up under that scenario, or are we discussing everything above ​the already torqued assemblies ?
  5. #185
    Sep 2014
    Moneta VA
    I have not started fabricating anything yet.
    The neck and bearings I assume I will get on Christmas (so I have not seen them yet)
    I have two 9X12 1/2 inch plates to fabricate the top and bottom from
    Thank you
    Bob
  6. #186
    Apr 2015
    Batesville, AR. 72501
    Bob,
    I've been following this thread and had an idea that I thought I'd throw out there.
    You could add an oil seal to the top and bottom Triple Tree plates by welding on a piece of tubing with an ID equal to the OD of the seal you would use and turn and polish the OD of the neck piece equal to the ID of the seal. The picture is a little blurry, sorry.
    Looks like this would seal up the whole neck bearing area.
    Never tried this. Just a thought.
  7. #187
    Sep 2014
    Moneta VA
    Quote Originally Posted by vwbug72501 View Post
    Bob,
    I like that idea.
    So basically the seal would be on the outside on the neck instead on the inside, then a ring welded on the outside of the seal.
    The seal would fit between the neck and the outer ring
    Then I could use something like this https://www.amazon.com/dp/B005M2SJ4A/ref=biss_dp_t_asn
    Thank you
    Bob
  8. #188
    Apr 2015
    Yep. Rings welded to top and bottom plates of the triple tree to hold the OD of the seal.
  9. #189
    Jun 2016
    milnor n.d. usa
    Default reply
    I like the seal idea on the neck tube......the only thing I would consider, would to maybe use an all rubber seal, or double sided seal, and just glue it on to the tree. Or would filling cavity of seal with rtv hold the seal to the tree??? would save welding and boring. Might use this trick when and if I ever change neck bearings. my .02
  10. #190
    Sep 2014
    Moneta VA
    and I can get them incrementally smaller to compensate for the shaft size after it is polished for the seal
    https://www.grainger.com/category/ro...FN-kz2Z1z0o03d
    Thank you
    Bob
  11. #191
    Sep 2014
    Moneta VA
    Great Ideas!!!
    Thank you
    Bob
  12. #192
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I built my trike in 1972. No seals relatively close fit between the neck and trees. About six years ago took it apart to check things out, cause the front end had a little play. Repacked bearings they were fine. No rust and very little dirt. Just sayin those bearins aren't movin around much.
  13. #193
    Sep 2014
    Moneta VA
    So are seals really needed?
    If I did use seals on the the outside of the neck and glued them on with RTV that should not hurt anything and not cost much and if I do not have to weld a outer ring then its not hard to add it
    If I do have to add the outer ring it still would not be hard to do but I would have to get the rings machined that would cost money and that is kind of on short supply right now
    I have some time before I get the neck so I will research as much as I can before then
    Everyone keep the ides coming. The different suggestions are very helpful and making me think
    Thank you
    Bob
  14. #194
    Jun 2016
    milnor n.d. usa
    Default reply
    Thinking this morning....my situation...neck and forks are assembled, not going to take apart to make better seals.......thought of butt glued o-rings.....maybe I could wrap a square cross section seal around neck tube ,butt glue ends of seal, then glue seal to the trees??? Bob.... glad you got us thinking about seals, my front wheel throws up a lot of sand and rock. I ride on gravel roads often.
  15. #195
    Apr 2015
    Great discussion. I'm thinking that seals become more important if the trike sits outside uncovered a lot where water can collect and start rust.
    Sidecarbill's experience shows that a well fit and lubricated bearing is probably going to operate well over time.
    LarryA's comments about sand and gravel are valid but I'm thinking that if the sand can get into the neck bearing area then water could also get in there to wash some of it out during rain or washing. I've ridden metric bikes with ball bearings and just a sheet metal cup water shield for the neck bearings and they have performed well even when "crunchy".
    I'm not a big fan of permanent solutions depending on adhesives because they usually fail due to the different expansion coefficients of the materials. I realize that adhesives have come a long way but my 2014 Durango already has body panels coming loose because of adhesive failures. I also have a 1957 Dodge panel truck where the mechanically fastened trim pieces are still in their original positions.
    Unless you're riding The Tail of the Dragon, these bearings don't move more than 180 degrees and not very fast so seal surfaces don't have to be super smooth. This might be much ado about nothing but a good exercise for your initial design considerations.
    Just my (wordy) $.02.
  16. #196
    Jun 2016
    milnor n.d. usa
    VW Bug...Lol.....went out and actually looked at the trike neck.....radius on back of trees matches neck radius..so..no room to fasten a seal on the back area of the trees,......my greased leather washers will have to do. Stored inside most of the time anyhow.
  17. #197
    Sep 2014
    Moneta VA
    So I have the neck now
    Its nice and thick
    I'm building a leading like
    I already have the plates for the top and bottom triple trees, I need to figure the offset and width
    Tomorrow I am headed to the local metal suppler to buy some 2 x 3/16 square tubing for the forks
    I need to get a wheel and tire before the fork build so I will know what width to make the trees and forks.
    I'm thinking of a 21" X 3.5 wheel (like I have on my other trike)
    Or would a shorter wheel be better?
    Is a 3.5 width wide enough?
    I'm also thinking about a 40 degree rake
    My other trike has a 46 degree rake
    Any ideas/suggestions/comments???
    Thank you
    Bob
  18. #198
    Jun 2016
    milnor n.d. usa
    Default reply
    Well Bob, I had most of my trike built before finding Trike Talk. I don't know how much I would have done differently, with the knowledge available here now!
    Being a low buck project from the get go, I just used what I had,
    and what I could get, cheap.
    forks were copied from onetonmagoo's example. tubes 1.75X 1/4 wall dom. lower tree 1" plate. upper tree 5/8 plate. 750 honda rear shocks for fork springs. 1"X 3/16 wall dom for spring rods.
    offset was grabbed from a harley tree, Im' thinking 2.5 in.???? or thereabouts.
    trail 2"
    rake 45deg.......would go with 38/40deg if doing over, (mainly to keep shorter WB.)
    my front wheel is a rear wheel from a 750 honda 18 in. the 750 rear axle wt. rating was 600# plus. my front axle is 370# with me in the seat.
  19. #199
    Sep 2014
    Moneta VA
    Thanks for the input man. It all helps
    My first 2 trike were built mostly before I found any forum like this
    It wasn't until I was almost finished with the Heathen before I realized there were forums like this
    I always seem to be on a budget and do the same.
    I just started a new job so i cant go crazy buying stuff until I see how it works out
    I have though of a number of different designs but the 2 inch square tubing seems to be the easiest and will the best with my frame. I think a 3/16 wall is thick enough This is what I made the frame from and what the frame is made of on the Heathen. one issue is I have to buy 24 feet of it when I most likely only need 6 - 8 feet for the forks
    I have been researching offset. I don't want to make it to much because it affects the trail. I think I will make everything out of wood before I cut up the only metal plates I have
    trail 2"
    From what I have been reading 1-2 inches is the best for a Trike
    I can adjust my trail several ways but I believe the most adjustment will come form the rocker length
    From what I have been reading Rake is not as important as Trail but the rake can affect the trail, wheel base and steering radius
    I only have some skinny motorcycle wheels so I have to buy some. I had some car wheels and tires but my son needed them.
    Mostly what i find is 3.5 inch front wheels. I could use a back wheel on front but since I have to buy it first I have to gather as much info and possible before I make a purchase
    I am still not sure what front wheel I will use and until I get it I cant design the forks
    Thank you
    Bob
  20. #200
    Sep 2014
    Moneta VA
    I got the plates I though where 1/2 inch out of the shed but found out they were only 1/4.
    Picked up a 24X9X1/2 plate
    I picked up 24' of 2" square tube (way more than I need)
    They gave me Free several 2"X12"X1/2 sections (for the rockers)
    Got the neck
    Got a section of 2" X1/4 angle (to weld the neck to)
    Need to figure out what Wheel I will use.
    Have not had much time to research it (the new job is using up to much of my brain power)
    Thank you
    Bob
  1. Happy Birthday Trail Blazer
    By Papa Zook in forum General Discussion
    Last Post: 12-07-2016, 02:39 PM
