Likes Likes:  9
Results 1 to 8 of 8
Thread: COOLANT on Your Tri Glide ????
    2000+ Posts Rollin Thunder's Avatar
    May 2013
    SUN CITY WEST. ARIZONA
    Default COOLANT on Your Tri Glide ????
    I advise EVERYONE with a TRI GLIDE to check your coolant levels.
    It's on the right side lower. Just take a small screw driver and pry one end off then the other starting from the top.
    I checked mine last night when Randy came over after he had to replace a coolant pump and some hoses on his 14 already .
    EASY enough to do but you might want the piece of mind before it ends up costing you BIG $$$.
    Rick
    150+ Posts Triglide1950's Avatar
    Sep 2017
    Chanhassen, Minnesota
    Hey Rick
    Great reminder for every TG rider. It's part of my weekly check list, I check it more frequently during hot weather.
    US Army, SGM Retired
    Patriot Guard Riders, Legion Riders, HOG Member
    Dignity, Honor, and Respect, Never Forget
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I lost my pump in Ottawa Ontario last summer at the HOG rally. Neither dealer had one. Dealer said it wasn't a problem as long as I stayed away from congestion. Took bus/cab next two days. Headed home on Sunday and tried all dealers on the way. Finally found American Harley in Tonawanda, NY. (340 miles) that had one. they put it on and I went the rest of the way to Chicago with no problems. Dealer said "It's a Harley - it's basically an air cooled engine. Just don't get caught up in traffic for too long."
    IBA#61162
    PATRIOT GUARD
    USMC
    May 2013
    YUP. That's I heard from about a dozen riders already.
    The trouble is IF you DON"T have the extended warranty it's going to cost you close to $800.00 to have them do it if you pump goes out .
    Water pump $125
    Coolant pump $461
    Thermostat $80.
    Then the labor price also.
    Quote Originally Posted by Rollin Thunder View Post
    Water pump $125
    Coolant pump $461
    Thermostat $80.
    Gives you something to think about , Thats for sure...
    Sep 2023
    Fayetteville
    Rick
    Good info concerning the Coolant Level Check. Also check Your hoses. Mine was leaking from the the hose under the Pressure Cap. Changed the Hose Myself and coolant. Not an easy task but thanks to the info here and u tube made it easier than paying 300.00 plus. Check everything. Little simple checks will save a lot of Money. Dealership will charge a arm and leg .
    20+ Posts
    Jul 2022
    West Valley City, Utah, USA
    Not to take away from the OP's good advice, but I personally don't worry about it (2022 Tri Glide).
    I have a Dynojet Powervision on the trike, and it is set to constantly show the various sensor temperatures, with color triggers set to show red if any temperature goes higher than I like.
    I have also done a tank life, front and rear. That adds to cooling. Plus I have the cooling deflector wings. I also have the HD Coolflow fan, and also the Jim's Forceflow fan. Also stage 1 so that it breathes better, including an external breather. All of those mods result in a coolor-than-normal engine. If the temperature even went back up to "normal", I think I would notice-- especially since the Powervision would then be showing red.
    So I just watch the gauges, and ride.
    Nevin
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I learned the hard way also, 3+ years ago.
    www.DKCustom.com
  1. 2018 Tri-Glide colors
    By Zahnsflyer in forum Harley Tri Glide
    Last Post: 02-08-2018, 10:12 PM
  2. Trailer hitch for tri glide .
    By Rollin Thunder in forum Harley Tri Glide
    Last Post: 01-25-2018, 04:36 PM
  3. 2014 Custom Tri Glide
    By TriGlideJoe in forum Harley Tri Glide
    Last Post: 12-21-2017, 03:26 PM
  4. Rear tire tri glide
    By 67wizard in forum Harley Tri Glide
    Last Post: 12-20-2017, 09:49 AM
