Likes Likes:  76
Thanks Thanks:  12
Page 7 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 121 to 140 of 263
Thread: Lehman Trike Parts & Info Thread
  1. #121
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by cajunspeed481 View Post
    I've got a 2008 Goldwing 1800 with the Lehman Monarch II trike kit. Any ideas on where to get parts for the rear axle, need park brakes, axle bearings, disc brake pads, and seals.
    I can help www.mjtrikes.com. Have everything in stock.
    Jim Murphy
    Iron Butt Rider 2001
  2. #122
    20+ Posts
    Jan 2018
    West Portsmouth, Ohio, Scioto
    Default Leaking axle
    I need some help with my 2006 Goldwing Lehman Monarch II trike serial # C002338. I attempted to replace brake pads and the right side was a piece of cake but when I removed the rotor on the left side the brake drum was covered with it appears to be differential oil and the caliper was slightly wet inside. the whole area was greasy and caked in brake dust. it looks like I need a left side caliper and seal, also I was told at my parts store that the bearing was probably bad and ruined the seal. I bought the trike used and don't know what year the trike kit was installed. It is a straight axle. Would the park brake shoes be ruined too? Where can I get parts? Any help will be greatly appreciated. Thanks in advance.
  3. #123
    Martinsburg, WV
    Quote Originally Posted by Keith G View Post
    The caliper could be leaking, but that is unusual.
    Axle bearings and seals should be replaced in pairs.
    If you call me tomorrow between 9am & 1pm at the phone number on the www.mjtrikes.com website, I will talk you through the inspection process so that you can diagnose the problems and come to a solution.
    Jim Murphy
  4. #124
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Hey Jim!
    I have an '86 FLHTC with an older Renegade conversion equipped with drum brakes (trunk lid hinged at the top to give you an idea of the age). It's good right now, but eventually it's gonna need brake shoes. Are the shoes still available? Also, was there a trailer hitch made for the older conversions?
    PEACE and ride safe!
  5. #125
    Martinsburg, WV
    Quote Originally Posted by Doug D. View Post
    Hey Jim!
    They discontinued that conversion in or around 1998, it was prior to the Renegade and it was called the TOUR. Brake shoes, drums and wheel cylinders can still be obtained and they are fairly inexpensive. As far as a hitch is concerned, I made my own hitches even back then. I actually have a TOUR model on the floor that I might be able to mock up a receiver type hitch for your trike.
    Attachment 54803
    http://mjtrikes.com/shop/index.php?m...roducts_id=225
    Jim Murphy
  6. #126
    May 2012
    Vienna, MO USA
    Thanks Jim, I appreciate the help! About how much would you charge to do the mock-up?
    P.S. Thanks for setting me straight on the model, too! Been calling it a Renegade since I bought it last Fall.
  7. #127
    Martinsburg, WV
    After my last communication I looked beneath the Tour that I have will have to get back with you on a final cost b/c there are no mounting holes for a hitch on the tour.
    I will also have to see if I can configure a harness for the trailer too.
    Back then, Harley was not as sophisticated with their wiring and had very POOR ground (-). I will get back with you.
    Jim Murphy
  8. #128
    May 2012
    Vienna, MO USA
    Thanks again, I really appreciate your time!
  9. #129
    20+ Posts
    May 2018
    daytona beach florida usa
    Default Older Lehman kit
    Picked up a very low milage 98 HD Ultra with a Lehman conversion .( the trike kit looks almost new, no dings, scratches, etc..) How do I determine which kit it is for parts? I thought that it was a Renegade, but I just read that they had a "Tour" that looks similar.(trunk is hinged on top also if that helps). Is there an ID tag somewhere on the kit? Thanks
  10. #130
    Martinsburg, WV
    Quote Originally Posted by dedawg View Post
    No ID tag other than a sticker installed when new.
    Parts beneath the body are similar of not the same in the later Renegade. The trunk door is hinged at the bottom on a Renegade and at the top on a Tour. Other than that the bodies resemble each other fairly well. The driveline, brakes, shocks, body support and swingarm were the same from 1997 - 2002. If yours is equipped with drum or disc brakes, most of those parts are also available.
    The differential is grease-able and needs service at regular intervals so that the gears stay lubricated.
    Jim Murphy
  11. #131
    20+ Posts
    May 2018
    thank you
  12. #132
    May 2018
    VERNON, az usa
    Default 87 goldwing lehman
    Howdy I have what I am pretty sure is a Lehman strike kit on my 87 goldwing.
    What I am looking for is where the mounting bolts are?
    I found 2 steel angles that touch front by where passengers foot rest are.
    The each have 2 holes drilled into steel but nothing into the fiberglass of the fender.
    Any ideas of where the attaching points are?
  13. #133
    Martinsburg, WV
    George, A picture is worth a thousand words. A picture would help identify your trike as well as the area of concern. Thanks
    Jim Murphy
  14. #134
    May 2018
    VERNON, az usa
    Sorry I should have included pictures.
    I will post a few tomorrow as strike is at another location...
  15. #135
    Jun 2018
    Topeka
    Default 02 ultra classic trike
    I
    I have a 2002 Harley Davison ultra classic with a Lehman
    tried converting to and has a straight axle but it has a large heavy metal drum
    to the right of the sprocket and I can find no openings into it I now put
    10,000 miles on this bike since I bought it and I am starting to get worried about
    it Locking up. Is there a way like pulling the axles to get in there and back
    and that lubricant thank you very much and I hope you can help me
    And thank you
    rmcombs
  16. #136
    Martinsburg, WV
    Ralph, Contact me at www.mjtrikes.com
    Jim Murphy
  17. #137
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Hi Ralph! Welcome to the forum from west Texas. Jim is our resident Lehman expert - you are in good hands with him!
  18. #138
    May 2018
    VERNON, az usa
    Ok sorry for delay. I think I got a picture of the mount.
    There is one one each side front of fenders.
    As you can see 2 drilled holes toward the front up against the fiberglass.
    I started looking as there is some movement in the body.
    I think there should be a couple bolts to fasten this point?
    Quote Originally Posted by Sunpoweredaz View Post
  19. #139
    Martinsburg, WV
    OKAY !!! So post them ..
    Jim Murphy
  20. #140
    May 2018
    VERNON, az usa
    I have been trying with apparently no success in getting them to post.
    Anyone will to let me email them to you and possibly you can post.
    I am lost.
  1. 1994 Genuine Lehman Trike Build
    By Lee H. Mann in forum Trike Builds
    Last Post: 03-15-2022, 06:17 PM
