Likes Likes:  4
Thanks Thanks:  1
Results 1 to 16 of 16
Thread: Escapade Trailer Air Shocks
    Oct 2010
    Austin, TX
    Default Escapade Trailer Air Shocks
    Has anyone replaced the air shocks with coil over shocks? I've been in touch with CSC and they don't have a replacement for the air shocks and don't know when they will have a one. Precision suspension made then custom for CSC and don't make air shocks anymore. The top oring blew out of one of my shocks and I'm having no luck at finding the part.
    May 2018
    Angleton, Texas
    Quote Originally Posted by jmoraniii View Post
    Wish I could help, but I am in the same boat. Just haven't made time to pull the old shocks a try to work it out.
    give me a day to try and find the part numbers I have done this
    20180601 Trailer Shocks.pdf[ATTACH]70210
    Shocks from NAPA SENSATRAC 58275
    May 2018
    Angleton, Texas
    Thanks Ted your information will really help.
    Robert
    Oct 2010
    Austin, TX
    I rebuilt the shock with the rebuild kit sent by Progressive Shocks not Precision mistake in first post. The same thing happened pushed the oring out the top of the shock. I've called Monroe and Gabriel shocks and were told by both that they didn't have any shock that would work for the trailer application. The tech support for Gabriel shocks told me of a Co. in Colorado that makes custom shock. I'm sending my shocks to them to use the eye and post for a new set of air shocks with a 5 year guarantee. The shocks will be 1" longer with a 4" travel so with some air adjustment I should be able to set the ride height for the best ride. More than I wanted to spend $165 plus shipping, but between CSC and Precision there seams to be no replacement shock available any time soon. CSC says they have been waiting for a year for a replacement shock and don't have any yet. I will post on how the new shocks work after my trip to CA in June.
    Oct 2010
    Austin, TX
    Sorry didn't catch the mistake price was $265 plus shipping.
    I guess you did not want to try the NAPA COIL OVER shocks at 1/2 the price and stayed with the air shocks. Got 4000 miles on mine since I changed and am very happy with them. With 4.75 in of travel no worries and my wife weighs the trailer down pretty good. For anyone wanting to replace the air with coil over I can say they work nicely.
    Jan 2016
    Port Allen, LA
    Default CSC Shock Replacement
    Tired of dealing with leaks on the air shocks on my 2003 CSC Escapade Elite trailer. CSC now has a coil replacement shock.. $338 plus shipping...yikes!!!...Looking for other options...any suggestions??
    Aug 2021
    Prescott
    Default air leak
    So this was a direct swap ? I'm leaking air like the Titanic....
    Quote Originally Posted by Terrapinneck View Post
    Rickie........Welcome to Trike-Talk...........
    Small mods but basically a direct swap
    Still working great. I put about 3000 miles a year on the trailer. My only issue is I only get about 3000 miles out of the tires, but changing them is no big deal.
    Mar 2015
    Earlvile, IL, USA
    What mods have to be done to escapade trailer using the Napa shocks
    Quote Originally Posted by Dggrass View Post
    Hi sorry it's been over 4 years since I did the swap. I don't remember exactly what needed to be changed. I just remember it was not that complicated. I think it was something to do with the way the top of the piston rods went thru the trailer body, but it was not that much to make them work. I do not have the trailer so I cannot look to refresh my memory.
    Mar 2015
    Earlvile, IL, USA
    Thank you. I think I give it a try. The old air shocks leak and don’t want to worry about checking them all the time.
  16. Roadsmith banner
  17. #16
    Aug 2023
    Louisville, KY USA
    Default any update on the coil over shocks?
    Wondering if anyone has put the Monroe Shocks & Struts 58275 Shock Absorber and Coil Spring Assembly on their Escapade Trailer. Do you have to modify the trailer any?
  1. Replies: 5
    Last Post: 10-09-2017, 07:14 AM
  2. Escapade SE Trailer Wheels/Tires
    By knob in forum General Discussion
    Last Post: 05-19-2015, 07:06 AM
  3. Escapade LE trailer - installing mud flaps
    By hopefullysoon in forum Honda Trikes
    Last Post: 05-16-2015, 10:36 AM
  4. California Sidecar Escapade Excel trailer
    By williamschaz in forum Trailers / Campers
    Last Post: 02-19-2014, 11:22 PM
  5. Escapade Trailer Shocks
    By michael2480 in forum Trailers / Campers
    Last Post: 03-30-2013, 07:44 AM
