Likes Likes:  4
Thanks Thanks:  3
Results 1 to 20 of 29
Thread: BT -46 Tire Experience
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Default BT -46 Tire Experience
    Have anyone replaced the stock Goldwing front tire with the BT-46? I have 10,000 on my Trike and my front tire is up for replacement. I always put the BT-45 on my earlier Trikes but learned that the 46 has replaced it. Looks a bit wider but wondering if anyone has already replaced their tires with a 46 and how do you like. Thank you in advance
    250+ Posts
    Jan 2012
    oz
    IMO the Avon Front Trike tire can't be beat
    20+ Posts
    Nov 2020
    Blairsville, Ga, usa
    Default BT-46
    Quote Originally Posted by FRR View Post
    I'm watching this thread hoping we get some reviews. I'm ready to order a rear tire for the front.
    Thanks for the post
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by Baron56 View Post
    Thanks for the post
    I'm surprised no one has responded to this. Noticed fewer participates on the site. When I get my new tire installed later this winter I'll post results
    20+ Posts
    Nov 2020
    Default BT-46
    Read couple reviews on Amazon and other sites. All positive on Wing trikes.
    Have you found BT-46 lower than Amazon (shipped from Chaparral) @ 127.69?
    Born and raised in Alliance, OH. Ever get down to North Ga? I live just over an hour from the Dragon.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    That's just about what I paid. Going to wait to have it mounted until March/ So far, still wrapped up in plastic waiting for warmer weather
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I had it mounted a couple of weeks ago and put about 80 miles on it last week. Good traction and control. Much better than the stock front tire .
    Mar 2021
    Peoria, AZ, USA
    Default BT-46 on Goldwing Trike
    I ordered mine from Amazon and it shipped from Chaparral Motorsports within 3 days (after the dealer told me it was on backorder from their supplier). My cost was $128 and my dealer charged $60 to install since it wasn't ordered through them. They wanted $250 to order through the dealership and included free installation, so I saved a few bucks by bringing in my own tire. No complaints with the new tire on my 2019 Roadsmith trike after 3,000 miles. I'm hoping it lasts longer than the stock tire which lasted 12K miles. It's hard to say if the ride has changed materially compared to the original tire, but it definitely is as good or better.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by Timegger View Post
    My tire is on and has been since middle February. I'm here in Florida riding everyday. Front tire gives me better handling and stability. I never buy from dealers. Way too much money.
    20+ Posts
    Nov 2020
    Default BT-46
    Recently installed BT-46 getting ready to VA this weekend.
    Only have few hundred miles but loving it compared to Avon Cobra. Upcoming ride will be few thousand miles....we'll see
    Mar 2021
    Peoria, AZ, USA
    Now have 6,000 miles on the BT-46 front tire. Still no complaints and it looks like new. Tread wear is not apparent yet, but likely to start seeing some by the time it gets to 10K+. Will keep you updated if anything changes...
    20+ Posts
    Nov 2020
    Default BT-46
    We're back from Va. Total mileage was 1574 miles. Really like this tire compared to Avon Cobra.
    Played with air pressure, and as I did same with Avon......and its double edged situation. Meaning if you want softer ride you probably riding with low 30's in front and low 20's in rear tires.
    For handling and for me (2up) its minimum of 38-39 in front and 26-27 in rear. Ride wasn't bad at all.
    250+ Posts
    Jan 2012
    oz
    Low 30's if the front would be dangerous
    20+ Posts
    Nov 2020
    Update:
    3637 miles on the BT-46. Wear with depth gauge 7/32"
    Still loving compared to Avon. Better ride and handling....
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Is this tire mounted backwards then when you put it on the front?
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    20+ Posts
    Nov 2020
    Quote Originally Posted by BrokenBackJack View Post
    Correct.
    Disperses water better
    20+ Posts
    Nov 2020
    Default BT-46 Tire Experience
    BT46 tire update
    Just returned from trip to Oklahoma....2007 miles
    Tire now has 6745 total miles...wear is at 5/32.
    20+ Posts
    Nov 2020
    Default BT-46
    After 9383 miles on BT46 I had to change front tire. Wear was down to tad less 3/32"
    Leaving on trip next month to Wisc/upper Mich that will be at least 3k miles.
    I now have a fresh BT46 born Dec last year.
    I've never got more than 12k on many, many miles on two wheelers.
    So I'm use to change front tire at least every year. Gonna put few hundred miles on it with 42lbs.
    Actually it rides pretty good with 42lbs.
  19. #19
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Actually, it rides pretty good with 42lbs.
    Thanks for the update on these tires. I usually run 40 in my front tire - currently have about 6400 miles on my front tire and it looks pretty good.
    My bikes usually get about 21K on the front and rear tires. Now that i have moved to the trike, nt sure what to expect.
    See you are headed my way - Ilive in Lake Orion, MI. If along the way, you need something - drop me a note.
    Don
  20. #20
    20+ Posts
    Nov 2020
    Default Thanks Don
    Thanks Don....my cell 770.595.2398..... send a text or call and if I'm close coming south maybe we can get together. Looked up your location.
    Doubt you will ever see 20k on trike front tire. But when you do change you would really like the BT46.
  1. Interesting experience at Dealership- rear tire on front related
    By DK Custom Products in forum Harley Tri Glide
    Last Post: 03-14-2016, 06:19 AM
  2. Who among us has experience in Trike tires?
    By Boscoporp in forum General Discussion
    Last Post: 03-12-2010, 11:28 PM
  3. Trigg Trikes Experience?
    By ricle41 in forum Outrigger Style Trikes
    Last Post: 12-11-2009, 10:36 AM
  4. Before & After Rake experience
    By moonstar in forum Harley Trike Conversions
    Last Post: 05-26-2009, 06:25 AM
  5. Carver One experience website
    By Chuck in forum Other Brands Trikes
    Last Post: 05-03-2009, 01:13 PM
