ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Likes Likes:  5
Results 1 to 12 of 12
Thread: Foot Clutch Conversion
    Apr 2023
    Vernon Connecticut Usa
    Default Foot Clutch Conversion
    Looking for any information on foot clutch and Jockie shift recommendations busted wrist can't use hand clutch Thanks !!!
    Quote Originally Posted by Brete View Post
    Brette......Can't help much on the clutch......But Welcome to Trike Talk.....
    100+ Posts
    Sep 2018
    Martinez, CA, USA
    If you can use the clutch for shifting while moving, I would recommend a Rekluse clutch. This eliminated the need to clutch when stopping or going slow in traffic. There is a lot of info on this forun about the Rekluse clutch and a good video here
    50+ Posts nokkon wud's Avatar
    Feb 2021
    Clearwater, Fl
    I lost 75% use of my left hand. I went with a Rekluse clutch and like it. The only clutching I do is up shifting. I sort of hook my hand around the end of the clutch handle then pull my whole arm back.
    No clutching for down shifts or in traffic.
    The first 65 years of childhood is the hardest.
    Jun 2008
    Lovington, NM, U.S.A.
    Hello & to Trike Talk.
    Look into an electric shifter: http://www.pingelonline.com/prodcat/...c-shifters.asp
    Retired trike builder
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Quote Originally Posted by trike lady View Post
    That looks interesting even if you don't have any problems.
    welcome
    50+ Posts onebadeagle's Avatar
    Nov 2013
    Fredericksburg VA
    Default Rekluse Clutch
    I have the Rekluse Clutch and the Pingle Shifter due to crushed left ankle and arthritic left hand, These 2 items are keeping me in the Wind. Both are good additions.
    Apr 2023
    Default Tri Glide foot Clutches
    Had checked out reckluse clutches rather go with foot clutch Found some older threads with info but the sources for parts are old info. Thanks for suggestions will fabricate somthing.
  11. #10
    Jan 2009
    MA,
    Last summer a guy brought in a 98 Fat Boy 2 wheeler with a home made foot clutch & hand shifter we got it running for him, I got on it put in gear let clutch & it did not work smoothly it would catch then bind up I cranked the throttle did a half wheely it stalled I called the guy told get this the F out of hear before I die, I can usually ride or drive anything. He came down jumped on it put in gear no problem & took off. I think it would be good on a trike. I had seen kits for Tri Glide some were before .
  12. #11
    20+ Posts
    Dec 2021
    Apex NC
    Default Foot clutch
    I have a 2021 Tri glide and also issues with my left hand. Would love to have a foot clutch hand shift but haven’t had any luck. 2 dealers told me they couldn’t help and that would probably void any warranty and a independent shop said because of Abs and brake system probably cause issues? Also heard lots of other negative comments, all I know is that in the 70’s and 80’s that’s all I rode with and loved it. Seems with all the aftermarket things you could buy someone would make a kit . Maybe in the future!
  13. #12
    60+ Posts
    Jul 2009
    Donalsonville Georgia
    Quote Originally Posted by Zigzag View Post
    I have converted my 2010 triglide into foot clutch . got bored one day and remembered my 80s shovelhead with a slapstick and suicide clutch.
  1. Hydraulic Foot Clutch - HELP
    By Zaven in forum Enabled Trikers
    Last Post: 09-22-2020, 11:17 AM
  2. Anyone found a Hydraulic Foot Clutch/Hand Shift Arrangement for Current Generation HD
    By Free Bird in forum Harley Freewheeler / Road Glide 3
    Last Post: 06-09-2019, 12:31 PM
  3. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
  4. Foot clutch and tank shifter
    By Bruce in forum Harley Trike Conversions
    Last Post: 12-27-2010, 07:13 PM
  5. right foot throttle (foot accelerator)
    By roadkill in forum Harley Trike Conversions
    Last Post: 10-01-2009, 09:26 PM
