Likes Likes:  5
Thanks Thanks:  2
Results 1 to 18 of 18
Thread: Leans in corners?
    May 2023
    Jefferson
    Default Leans in corners?
    I am new to this forum. Thanks.
    I have a 2014 HD Ultra Limited with a new CSC conversion. Bike leans in the corners and very sensitive steering. Ride is very comfortable.
    Should I put a steering dampener on, and some kind of anti-sway bar?
    Quote Originally Posted by rmonthei View Post
    Randy ...Welcome To Trike-Talk......How much air do you have in the front tire?...anything over 36...Cold is too much....As far as the leaning in corners i never heard of a trike doing that?...At least not a CSC....
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Sir - welcome to Trike Talk. Congrats on your new CSC conversion. Before I got my 2021, I had a 2014 Ultra and was considering triking that.
    Please do post a picture so we can see your new trike.
    My trike does not "lean into the corners - trying to imagine what you are saying. You did mention that the steering is very sensitive. Sounds like you had a rake kit installed - do you recall what degree you got. For my Ultra, I got 11% - and believe this is the right thing from your bike.
    Also, what installed your kit?
    Finally, CSC has a passenger comfort ARB package that is designed to give the passenger a more comfortable ride. Don't think that has any effect of the bike handling.
    By the way, I run 40 in my front tire and 26 in my rear tires. Have a very smooth ride and handles well.
    750+ Posts
    Jan 2010
    east windsor ct
    being independent that is the nature of the beast to some extent
    randy welcome
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Welcome to Trike Talk Randy!!!
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    Hi Randy, to Trike Talk
    Does your trike have independent rear suspension?
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Given he said it was a new CSC conversion, I have to imagine it is Independant (Daytona conversion package).
    May 2023
    Jefferson
    Quote Originally Posted by cycle7447 View Post
    Yes it is Independant suspension.
    May 2023
    Jefferson
    Yes it is Independent rear suspension.
    May 2023
    Jefferson
    Default 2014 Ultra Limited CSC 2023.
    I should have listened to Joe at C&C Custom. He said I should ride it 500 miles. Riding a trike is a very new experience. Once we got used to the way a trike handles it is a dream come true. Best ride of anything I have ever rode on or in. Very comfortable and the wife is so very happy she is looking forward to more rides. Harley Trikes do not have IRS. I have a bet with someone that says they most definitely do.
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Sounds like you got it all worked out. Like you, I enjoy my trike. Please do post a picture.
    And, the Harley TriGlide does not have independent suspention
    Not from the factory anyway….
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    HD does not have IS from the factory,but a couple companies offer it as an add-on
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    I consider mine a Harley Trike. Never called it a TriGlude. My trike has the CDC conversion.
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    Welcome from Indiana!!!
    Bob
    300+ Posts brianl's Avatar
    May 2013
    leominster, ma. USA
    By leaning in the corners I think he means that it leans away from the direction he’s turning. I had a 97 wing with a Roadsmith standard sway bar. 5/8” diameter. If I took a right turn the body would lean to the left and vice versa. It would make my stomach do somersaults. I had the heavy duty sway bar, 1”, and it made a world of difference. I don’t know what CSC has but it probably rolls a little being an IR suspension. If you’re not used to it, it’s not a good feeling.
    Quote Originally Posted by brianl View Post
    If you go to the OP ‘s post # 11….Every thing is peachy keen now….
    His light bulb “💡”…Turned on…😳..
  1. Leans left with left hand turn
    By Clevelandpat in forum Harley Trike Conversions
    Last Post: 03-26-2023, 09:05 PM
  2. Harley champion trike leans
    By Joedo22 in forum Harley Trike Conversions
    Last Post: 07-06-2021, 07:14 PM
  3. Handeling corners & curves?
    By Okie in forum New Member Introductions
    Last Post: 10-01-2016, 09:19 AM
  4. 3 corners plus hawaii trip
    By Calman in forum Other Rallies & Rides
    Last Post: 05-14-2011, 11:09 PM
  5. Four Corners
    By Sharpe7Tex in forum General Discussion
    Last Post: 04-18-2008, 11:25 PM
