my new trailer build
Aug 23, 2016
21
17
Morrilton
used part of an old motor trike body . did my own fiberglass ,frame, axle myself. has surge brake that i design myself using Suzuki 750 front rotors and rear master cylinder made my first trip thru the Ozarks in Ark. and pulled great.
Great job!
My favorite part? The cooler-- for having some cold beverages at the end of the trip. :D
the hardest part was getting the paint to stick to the roto mold rtic plastic cooler. but with a little mold release remover and plastic bonding compound I was able to do it
beautiful!! I'd be proud to pull that.
thanks bill i sure am. with the surge brake installed the trike stops as quick as it would with out the trailer it has a Harley Davidson rear shock with out the spring inside the 2x2 tubing to damper the shock load plus the springs are adjustable for pressure to the master cylinder. it also has a electric solenoid that is hook to the reverse to lock out the brake fluid going to the calipers when backing up a hill .the hitch coupling slides on a 2x2 pieces on delrin that is slotted.
neil wright
neil wright
