Hey all. Just the other day I had the dealership install a set of HD Airflow black heated grips part # 56100358. On the ride home, I could not get them to work. I am assuming that I am not positioning the dial correctly. Is there a user guide available? I don't know where to position the '0', which I presume is off, as a starting point. If I twist the top of the dial toward me, until it stops, and I can see the '0', am I to assume that is off? But if it is, then the top of the dial doesn't twist away from me to get the number 6 to the same stopping point. It will only turn until number 3. The dealership is 'shut down' until further notice, by the Governor's order, due to the COVID-19, so I can't inquire there. Thank you for any input.
