Roadsmith Trikes
Sponsor - Roadsmith Trikes
- Thread starter
- #121
Glad to meet you RS !! We recently purchased a 2007 Goldwing trike (Roadsmith kit). Before this purchase we owned a 2002 trike (Lehman kit).
We love the independent suspension ...a real comfortable ride. We've had it out a total of 4 times since the purchase in May and already a couple of things have arisen. Took it out of the garage yesterday hoping to get a ride in and there was oil on the floor. Pinion seal was leaking and we're in the process now of getting/replacing that.
While under the trike, my hubby noticed that the shock springs have been rubbing on the inside of the tires to the point of rubbing the letters off!!
These are original tires put on by Roadsmith dealer in Rome, GA in 2009. Bike has 37,000 miles on it and no idea how long this rubbing has been going on. Recommended air pressure per manual is 35.
Our Lehman ran 20...big difference. That's neither here nor there as kits are completely different in many ways but thinking 35 was a lot.
Is this a problem that has ever been brought to your attention? What can a person do to remedy?
Looks like two new tires go on the list along with the pinion seal. Disappointed....
I'm sorry to hear of the issues with the pinion seal and tires.
Your mechanic has been in contact with our team here at Roadsmith, and we are confident you will be back on the road soon. Both repairs are relatively simple and your mechanic sounds like a top-notch wrench.
Recommended air pressure in our rear tires is 26-30lbs.
Load, ride quality, and driving style will determine which end of this range you should be at. The more load or the more aggressive driving?
You should be at the higher end for air pressure. Vice-versa for more sedate driving or desire for softer ride.
Standard tire and rim size is 16x7 rims, with a 205/65/16 tire. Alternative sizes can be used, but "rim width" and "rim offset" need to be considered to ensure proper fitment within the wheel well.
Meaning, the rim cannot be too wide (or it won't fit), and the overall diameter needs to be about 26" (rim with tire) to make sure the gear ratio is correctly matched with the differential.
Please let us know how the repairs turn-out, and for sure contact us if any questions.
Jim
