I have a 07 SE Ultra a with Lehman Renegade conversion, 110 CI engine, big sucker AC, Rhinehart true-duals with quiet baffles, and Thundermax ECM with Auto-Tune. The previous owner of the bike had installed the air cleaner, true duals, and PCIII USB (including tuning time on the dyno).
I had the trike conversion installed shortly after purchasing the bike, so I don't know what the fuel economy was as a two wheeler, but as a trike I got around 32 MPG , at 60 - 65 MPH, 5th gear, 3000 - 3200 RPM.
The PCIII went TU, so I decided to replace it with the TM w/AT. Installation of the TM made a vast improvement in the low end torque, and throttle response, however the fuel economy under the same conditions is 32 MPG.
My question is: Is 32 MPG reasonable for fuel economy, or should I be looking into the fuel map, timing, etc.
Thanking you in advance for your input.
