rear view mirror
Dec 15, 2010
111
17
Las Vegas, Nv USA
just had my right mirror pulled off here in mexico. Is there a secret or preferred method for getting it snapped back on? Doesn't look like any damage really. Thanks for any hints. Terry
Just line up the pins with the clips and push hard. Put it in at a little angle and it will go in easier. I kept knocking my left one off getting into the trike until I figured out how to get in it properly. Rick
I think that TMS started to add a zip-ty to the inside area to keep the mirrow from falling to the ground. Still need to pull my off to install !!
Tomg
My left mirror has come loose several times, mostly when I'm shutting the hood or hit a big whole in the road:AGGHH:. I start on the back pin and with a little pressure the front two snap right in.
Ed, the next time that happens . . . consider a plastic tie like Tom indicated. I had to pull the mirror off when replacing the side panel and "threaded" a tie thru/around the "guts" of the mirror to the inside panel. Snug up tightly, and you should be good to go.
crazybiker 46
crazybiker 46
