Gorilla
I have the cams in my 110. Right now I am out on my first long ride with them. I used a TTS tuner and had the Wiz do the tune. I support all that Steve says. I did not run a dyno on her but from my past experience this 110 is doing every bit of the numbers he mentions to expect. Just for an example I am cruising down the expressway at 65 MPH in 6th gear turning about 2500 rpms on cruise control. When it comes to a sizable hill here in North Carolina she will drop to 64 mph as it starts up the hill accelerate on cruise control to 66 as its going up pulls hard all the way not slowing at all. It will pull from 62 mph also in 6th gear. Just FYI I changed my trans pulley to 32 tooth from the stock 30 tooth. Means I am turning less RPM's at 65 mph then with the stock pulley equipped TRI would be. This TTS cam definitely does the job if the ecm is tuned correctly. I fully believe that the cam is not your problem. Good luck I hope for you that the tech, can dial it in for you.
