topsgt75
New member
Yes Please!
Thanks Springman
I think this is the part number for the kit I used for my lights: 69289-05. I did a search on eBay and found a used set the was from a 2010-2012 Road King. The used set came with hardware and lens/lights. If you get a kit from Harley, the lens/lights will be additional. The ground wire attaches to the light housing and grounds through the frame. I just had to run one wire from each light to the wiring harness/accessory wiring connector I used. Mine stay on all the time, I did not wire them through a switch. They are even on with high beam.
Pics to follow.
Yes please post the part number and the pics. Did you do your own switch and wiring also? Any help would be appreciated.
See my post above to Springman2007.
I did not use a switch for the lights, I ran the hot wire to an Accessory connector(I think it is the running light connector in the main harness, I can give you the location for it!) because I wanted the lights on all the time.
Pics to follow!!!
PM me if you have more questions.
