I have a Lehman Roadking conversion with champion reverse. I was able to put in reverse but then will not shift at all. Anybody had similar problems?
Welcome to Trike Talk.... And more info is needed on your problem..
Is is a mechanical reverse?.. And if so did you put it in first before you took it out of reverse?
And then the gears jammed... :Shrug:
Sounds like you didn't read and understand the operating instructions. Probably grenaded the reverse gear. Ouch!
http://www.championsidecars.com/uploads/5/2/6/7/5267613/reverse_6_speed_flh_09-up.pdf
yes, it's mechanical. Yes, I did put it in 1st before I tried to take out of gear. It's only the 2nd time I've used it.
Thats why Motor-Trike has a electric lock out... With their reverse you can't engage first gear while in reverse...
But if HD46MAN..The OP.. Just jammed the gears he might be able to free it by rocking the Trike back and forth.. [vigorously with help from a friend] :Shrug:
Thanks, that worked! Relieved!
Thanks everybody for your input!
it is a SM5. Manual transmission. It was in first gear, wouldn't shift to any of the forward gears. Finally got it to go into reverse. Now won't go into any gear.
I'm confused i guess you have a Spyder... When mine would act up [08]
Just a hair low on the dipstick [oil] would cause it. :Shrug:
