Davep1DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
ADSavarese2rhino 2New Member Introduct...New member from FL
ADSavarese2ADSavareseNew Member Introduct...New member from FL
Likes Likes:  700
Thanks Thanks:  56
Page 18 of 33 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 ... LastLast
Results 341 to 360 of 651
Thread: 88 blazer trike
  1. #341
    750+ Posts
    Jan 2010
    east windsor ct
    i think you will find a nicer ride if you start with the pivot point about an inch below the axle
  2. #342
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    OK I will plan on having the pivot point lower as you guys suggested
    I just received my 1" hole saw in today It came real quick
    I'm debating if I want to make the forks wider. I have 1 inch clearance between the tire and the side of the fork but I have to mount my shocks a little off center of the rockers and down tubes to keep that 1 inch clearance
    If I decide to go wider it will delay things. I have the money to buy more plate steel but don't have the time to go get it.
    Im sucking up to the Ol'Lady now in case I need her to go get it
    Thank you
    Bob
  3. #343
    Sep 2014
    Moneta VA
    Just ordered more plate steel
    Talked the Ol'Lady into picking it up Thursday.
    Thank you
    Bob
  4. #344
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Fowler View Post
    didnt notice what u got the hole saw for but.. it will not make a very tight tolerance hole... it will be quite a bit over
  5. #345
    Sep 2014
    Moneta VA
    Quote Originally Posted by stacebg View Post
    Well that sucks...
    I was planning to use it for the neck stem holes in the upper and lower plate and the hold in the rockers for the axle. The axle is 3/4 but I am using a 1" spacer that reduces it down to 3/4"
    I will have some extra plate steel and will drill a test hold in it first
    Question???
    what lubricant should I use when drilling these hole?
    I need to be able to get something from the local hardware store, Lowes, Ace someplace like that
    Thank you
    Bob
  6. #346
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    I use 3 in one or Marvel Mystery oil for drilling steel
  7. #347
    750+ Posts
    Jan 2010
    east windsor ct
    Well that sucks...
    Question???
    not much chance of that being a good fit... even a good drill will drill over.. best bet is a 31/32 drill an a 1" reamer esp for the rocker
  8. #348
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    have never used a hole saw for drilling thick steel.....but would agree with stacebg that even with a pilot the 1 in. hole saw will wander enough to be oversize. can you find a local machine shop or weld shop that could plasma or waterjet those holes? or even drill undersize and ream to size. or worse case, buy a drill bit and adjustable reamer on e-bay, I see a lot of crichley adjustable reamers sets fairly cheap. I have drilled a lot of 3/4 to 1 in holes on my 1/2 inch drill press......also have drilled many holes with an old post drill fasted to the garage wall .....they had a rachet power feed that worked well...of course you cranked by hand. with a slow turning bit and heavy feed pressure I have drilled thru leaf springs on occasion.
  9. #349
    Sep 2014
    Moneta VA
    OK so I need to order a new drill bit
    Should I use a drill bit or hole saw?
    You stated a 31/32 just want to be sore that is correct before I order it.
    any other suggestions before I order?
    Thank you
    Bob
  10. #350
    Jun 2016
    milnor n.d. usa
    Bob if you drill or hole saw...you will need to ream the hole to get it straight and round. If the drill bit is sharpened correctly, a 31/32 hole should clean up with a 1 in. reamer. That is why you drill a sample hole in a piece of scrap steel. if in doubt use a 15/16 bit. The reamer will pull harder with the smaller bit of course. with an adjustable reamer you can increase hole size in steps. Working 1n. holes will require a drill press that turns slowly. the adjustable reamers are to be turned by hand.....the chucking reamers are used in a drill press turning slowly with plenty of oil....cutting oil preferred, but engine oil works, not as well, but I don't like the smell of hot motor oil... For 4 drilled and reamed holes farming out to a machine shop may be cheaper? Others may have ideas or suggestions. Good luck on this project.
  11. #351
    Sep 2014
    Moneta VA
    but getting time to take it to a machine shop is not easy.
    I just looked at my hole saw. It is not actually 1 inch. It is 25mm (from Japan)
    I just picked up some cutting oil from Ace hardware I am going to try it tomorrow on some scrap 1/4 plate
    If that does not work I will buy a 31/32 drill bit
    Thank you
    Bob
  12. #352
    Sep 2014
    Moneta VA
    so what am I looking for in a drill bit
    https://www.ebay.com/sch/i.html?_fro...l+bit&_sacat=0
    Thank you
    Bob
  13. #353
    Jun 2016
    milnor n.d. usa
    ya the 14 dollar one should work. I usually drill a pilot hole slightly smaller than the thickness of the drill web......that is the width across the point of the drill bit. It helps the drill feed easier. A larger pilot hole can sometimes let the bit wander and chatter. experiment on a scrap piece. The new bit should drill close to on size. At work we sometimes needed a larger hole than the bit had available, so we would hand sharpen the bit, grinding uneven cutting edge lengths, to make it drill slightly oversize.....not always successful!
  14. #354
    Sep 2014
    Moneta VA
    Default hole saw test
    here are the results of my hole saw test
    Thank you
    Bob
  15. #355
    Jun 2016
    milnor n.d. usa
    seems like a pretty good fit!
  16. #356
    750+ Posts
    Jan 2010
    east windsor ct
    looks good... i am surprised
  17. #357
    700+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Oh Yea of little faith.... I've had good luck with hole saws on projects like this. Some caveats: Slow speed and plenty of lube/coolant. Subsequent holes may not be as pretty or precise. A second hole saw is always a good investment......You'll use it again sometime anyway.
    As for drill bits.....MADE IN USA!!!! My experience with Made in China is that they aren't worth the blisterpack they come in.
    These guys are pricey but their stuff is good! https://www.mcmaster.com/#drill-bits/=1e7nixt
    Again, you'll use it again sometime.
    Prepare for the Apocalypse. Collect tools. The man you can fix things won't starve!
  18. #358
    Sep 2014
    Moneta VA
    Started by drilling a pilot hole through both plates
    Had to take it down to 1 plate at a time because it would not go through both
    Also it started clogging up I had to clean it a lot
    It went through 1 plate at a time fine just had to clean and oil it often
    on the trike. The stem bolt fit real well but it is to long. I will have to get 3/4 inch more thread cut in it
    Once I am finished making it I will have to figure out something for bearing seals. We had talked about this in the past and you all had some good ideas
    Next weekend I will work on it more. I have to start painting a room now. (promised the Ol'Lady)
    Thank you
    Bob
  19. #359
    Apr 2015
    Nice work Bob. Will cutting longer threads on a grade 8 bolt be possible ? Will it mess up the integrity of the grade 8 hardness? I thought that the bolts were manufactured and then hardened to grade 8 specs including the thread areas.
    Maybe wait until you add the thicknesses of the bearing seal solution and then split the difference and add welded on spacers to the top and bottom tree outside surfaces. That would give you a little more load bearing surface area on the neck bolt.
  20. #360
    Jun 2016
    milnor n.d. usa
    Bob ....you have made me a believer in hole saws! That's true Tom.....maybe seal cups and sleeves will eat up some of the excess bolt length. I do think, the cutting of additional threads would definitley reduce the grade 8 factor, but the bolt would still have plenty of strength. the tension on the bolt would be only a few ft/lbs at the most, and the shear strength of the bolt would be much more than the fork assembly could stand without bending or breaking....just my .02.
  1. Happy Birthday Trail Blazer
    By Papa Zook in forum General Discussion
    Last Post: 12-07-2016, 02:39 PM
