Just wondering if any of you rotate you rear tires from left to right / right to left at various mileage intervals
No need for rebalance if you use http://www.ride-on.com/:clapping::Coffee:
The only True way to rotate the rear tires on a trike is to dismount the tire off the rim and reverse the tire on the rim.........Unless you have directional tires...:Shrug:
But then with over 45 thousand miles on my 11 the tires were still good [Wearing even] when i traded it in..
I think he means, to dismount the tire from its wheel and flip it around so that the outer sidewall is now inside, and then move the tire/wheel assembly to the other side of the trike. Doing it that way means that by rotating from side to side the tire still rolls in the same direction.
Ok now Im confused.
I was under the impression you cant rotate rear tires on a trike say left to right...... I have Goodrich TAs. Radials but non directional I believe. Havent ever really read the tires markings.
My right is a bit more worn then the left but not terribly at 27K miles. Ive obviously never switched them around. Ive always been of the school of front to rear on the same sides OK with 4 wheelers. But not left to right/right to left as on a trike????
