Likes Likes:  5
Results 1 to 7 of 7
Thread: Newer Batteries with 425 - 500 and 600 CCA Ratings
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    Default Newer Batteries with 425 - 500 and 600 CCA Ratings
    I'm seeing new batteries claiming some impressive CCA ratings. How is it that all of a sudden with a minimal rise in Battery wt. {more lead?} CCA ratings have jumped from basically 310 to 600?
    Thanks for your thoughts - jc
    If they are lithium ... apples and oranges ... but my guess ... Like everything else ... technology has gotten freaky good ... My iPhone is now more powerful than the computer that landed a man on the moon ... go figure.
    My theory ... alien reverse engineering ... ... just saying.
    200+ Posts
    Nov 2016
    groesbeck texas usa
    ​I'am ordering a YUASA 500 cca to replace the stock battery in my 2016. Stock is 405 so I'll give it a little boost
    Apr 2015
    Quote Originally Posted by lightnin View Post
    Be great if you can give us an update later. Thanks jc
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Just curious, where you ordering it from?
    Jun 2010
    Coram, NY USA
    Love to give the battery companies credit, but I am going to guess the method of calculating CCA has changed.
    Oct 2017
    St. Louis, MO USA
    Size 30 AGM batteries in the 385-400 cca range are fine for these trikes.
    Unless your at 0° degrees, your not seeing cca anyway. The lithium batteries in our size are pushing 35-50 more amps for a battery less than 1/2 the weight. You then have to change your charging system.
    When mine goes belly up, I think I'm going with an AGM battery, as they are getting better. Im gonna give the lithium style a few more years of improvement before I test the water.
  1. Battery Tenders and Lithium Batteries
    By Jack Klarich in forum General Harley Chat
    Last Post: 12-20-2017, 04:26 AM
  2. 2011 and newer can bus bcm codes
    Last Post: 06-24-2017, 07:09 AM
  3. 2013 and Newer HD Trike's ..
    By Rollin Thunder in forum Harley Tri Glide
    Last Post: 02-18-2015, 02:34 PM
  4. 600 miles
    By morrishuckeba in forum General Discussion
    Last Post: 05-24-2011, 04:45 PM
