Has anyone been successful or tried to obtain more hp and tq from their Stallion?
Wow, that was a good hp increase, I'm thinking the tq was pretty good as well according to your description of the power feel uphill and how it reacts. Also by using premium unleaded will be a plus in making more power if you had regular gas. I will definitely do this as well. Thanks. The average charge now for dyno tuning in my area is about $700.00
Good morning
results show what a good tune can achieve. I am curious tho on how the timing was changed, I thought it was only accessable through ecm. so you can access ecm and change other parameters also. I was under the impression you could not reset any parameters with the roush chip
Dragon
Thanks, did he have to access the ecm through a special cable, take off the front cover and then plug in? this sounds very interesting, can a dumb nerd like me get a license:Shrug: and learn the process:xzqxz:
Dragon
I heard something about the chip being installed, is this a piggy-back chip plugged into the ECM?Good morningresults show what a good tune can achieve. I am curious tho on how the timing was changed, I thought it was only accessable through ecm. so you can access ecm and change other parameters also. I was under the impression you could not reset any parameters with the roush chipDragon
No chip or external programmer was needed to be installed. Did it with just a computer plugged in to the OBD II port.
Sorry, but I meant someone said there were Stallions with the Roush chip plugged into the OBD II port when they bought them.
