I've been looking and can't seem to find out exactly how you hook up the fuel line to the main tank from an aux. tank. I know you need a 90 degree bulkhead fitting and a check valve(aux tank lower than stock tank) but is the sending plate drilled and tapped, or just drilled and the fitting screwed in? Anyone done this? TIA
