ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  2
Thanks Thanks:  2
Results 1 to 8 of 8
Thread: How to clean residue from inside FLRT Free Wheeler head light
    60+ Posts Red sport.'s Avatar
    Sep 2019
    winfield, Al. Usa
    Default How to clean residue from inside FLRT Free Wheeler head light
    Bike got rained on head light got foggy did clear up some But needs cleaning, looks ok when light is off. looking for advice, thanks in advance.
    You can flush the inside of light with alcohol, let air dry, repeat if the haze is still there
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Question Jack...how would water get in the headlight? It would seem the entire housing would have to fill up with water, unless the housing is cracked
    It is not so much water, it is gases from the bulb. Very similar to what is happening with modern car headlights
    Our headlamps have a pretty good rubber on the back side, tho it cannot seal out all of the moisture IMO
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Had that fog inside the headlight. Used a chopstick un broken as a big tweaser and a big cotton ball to polish.
    Sep 2019
    winfield, Al. Usa
    Well, got advice from a friend, took light off & apart used windex 1 terry fiber cloth to clean & 1 fiber free to dry & a tooth brush handle good as new now. There is a hole in the bottom of the housing where the screw screws into the loose bracket, there is no gasket of any kind around the 2 rings that holds the light in. Bike is 4 yrs. old, rust inside bottom of housing. I thought about putting black elec. tape over the entire bracket (inside).
    My Sportster don't have a hole of any kind under it's light. Did clean it Yrs. ago thou.
    Sep 2019
    winfield, Al. Usa
    Default how to remove rust from vent holes on front disk bake?
    Bought this 2015 Free Wheeler with 3.400 miles on it in June 2019 so it's 4 yrs. old was told it was garage kept Well, must have been in a car port it has rust on brake rotor vent holes & bolts & screws, need advice on how to clean rust off. Google it there is 1 spray for 23$ that kills it. Want to know what you all use.
    Thanks in advance for all suggestion.
    Try some of Naval Jelly
    it will take some work, and you will have to stay on top of this as the rust will want to come back. The metal surfaces have already been etched
    Good luck and check back in
  1. 1st. ride on my FLRT Free Wheeler (about 10 ft.)
    By Red sport. in forum Harley Freewheeler / Road Glide 3
    Last Post: 11-04-2022, 05:13 AM
  2. Four Wheeler into Three Wheeler
    By Sully in forum Home Built Trikes
    Last Post: 01-03-2019, 11:18 AM
  3. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  4. To clean or not to clean?
    By bayoudave in forum General Discussion
    Last Post: 07-26-2013, 11:55 AM
