Hi all
I was checking the torque on the rear lug nuts. I thought I had set it at 100lbs. As i was putting the torgue wrench in its case I noticed I had set it to 110lbs. I went back and loosened the nuts and set them to 98lbs. I know that 10lbs is not that much, but they are made from aluminum. Do you think that I could have damaged them ie: stretched or cracked them.
I have read stories where wheels have come off/almost come off while riding. One guy found two lug nuts loose. Both had be cracked by over tightening. I know I sound a little paranoid, bot having a wheel fall off while going down the rode would defiantly run your day
David
