2015 Freewheeler cruise amber light will come on but speed will not set so no green light. There are no codes showing. Have ran the cruise diagnostic with the buttons, amber light just stays amber never goes to green. Whats next????
That is odd for sure
Have a look here and scan your ECM for a DTC
Most often the cruise control problems show up with a brake light switch code http://www.motorcycletireco.com/motorcycle-service/harley-fault-codes/
Very strange indeed. Harley has had a fair share of these new handle bar switches, I hope your left switch pak is not going bad. Does everything else work OK including the clutch switch?
Yes sir everything seems to be in order except the cruise. I was already thinking about the switch pack.. I have already checked on switch which is costly for a switch. Would like to know for sure it is bad before I spend that money.
thanks for your knowledge, If i find out for sure I will let you know..
I have no idea how to check for a signal, but it seems the speed sensor also comes into play. Mine will not set at 90mph or above. I probably shouldn't have posted this, but maybe it's something else to look for.
<br><br>I believe that is how it is programed just like it will not set below 30 either.
Did you run the diagnostic that Jack linked to? It test everything in the circuit. Watch the video and run it again. It tests your:
1. Cruise control switch
2. Clutch switch
3. Front brake switch
4. Rear brake switch.
5. Throttle switch.
These are what will keep your CC from working.
