Clevelandpat
New member
- Thread starter
- #21
Battery
I do have a Haynes manual..my next move is to go from switch onward see what is going on.
Ok. Looks like I had a couple corroded connections and the power issue is corrected. Engine cranks good but no start. No spark at plugs. Center wire to coil has power but nothing coming from coils. I read some other posts of a possible angle sensor. Where is it located? Any ideas?
Ok I found sensor connection at the module and tested sensor..1st test was .5.2nd test was 4.5 3rd 1.0. The connector seemed loose so I reassembled and it seemed secure. Bike starts right up and idles good..does not die in a few seconds like it did prior. I also went to the speedometer reset and read code d01clr. Is that code good? Thanks for all your help.
D01cLR...clear correct?
Yes cel is illuminated..dealer didn't have one the other day suppose to be in on Wednesday.
Seems to be inorder. Kind of a pain to get to by that filter. Anything special I need to know installing?
One question.. Will that failed sensor cause the electrical system to completely go blank. This bike will start and run 5 to 10 sec then quit. No lights no nothing. Wait about 10 seconds the lights come back on.
