Bonsai1BonsaiNew Member Introduct...New member from Texas
Sunman4BowdenTrikeHonda TrikesF1 Warning Light
LD-Ordie10Marc HNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie10ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie10ol' schoolNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie10SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie10Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie10LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  2
Thanks Thanks:  4
Results 1 to 5 of 5
Thread: Rebuilding A Tri Glide Reverse Motor
    50+ Posts Bouncer's Avatar
    May 2021
    Milwaukee, Wi, USA
    Default Rebuilding A Tri Glide Reverse Motor
    I just rebuilt an HD reverse motor for my buddy. It always had a weird gear sound and slow speed but finally quit working completely.
    Do yourself a favor, remove the body. 8 bolts some plug in wires and 2 people will make your life much easer.
    Three things I found during tear down.
    1. The brushes, although they were still in usable condition, were sticking in their housings.
    2. The rpm reduction gear compartments had lots of metal grit in the grease used to lubricate them.
    3. Small ball bearings.
    I completely dissembled the motor including removing the drive gear and actuation arm from the front housing.
    Everything got cleaned and inspected. The reduction gears, 6 of them, all looked good including the motor housing ring gear.
    I was surprised the reduction gears looked as good as they did because of the amount of grit I was feeling in the grease. I wasn't concerned
    with the condition of the armature because I wasn't reusing it. Luckily, I chose correctly because even though the old one was still functional,
    the worm gear on the armature that drives the reduction gears was worn badly. This explains the weird noise and grit in the old grease? The 6 reduction gears looked hardened and had almost no wear.
    The grease used in these reverse motors is not your conventional bearing grease. It's an extreme pressure gear grease w/moly. I chose 3% moly, you can
    get 5% moly online. Just thought I'd let ya'll know this in advance because it's not stocked everywhere.
    The kit I used included the front housing bearing, rear armature shaft cover bushing, brushes and plate, armature and solenoid.
    I installed the bearing in the front housing. There's a spiral lock ring that holds that bearing in. Next the drive gear assembly and actuating arm
    re-greased as from the factory.
    THIS IS IMPORTANT ....... there are 2 small ball bearings that drops into the bushing hole of the gear reduction plates. There are 2 plates that hold the speed reduction gears. Place 1 small bearing in the bushing hole of the first plate before greasing and installing the reduction gears. Now grease. Then install the motor housing over the first set of reduction gears.
    Next install the 2nd reduction plate into the first. The 2nd plate gets the other ball bearing in its bushing hole. That's were the armature shaft will go later. Now, install the reduction gears and grease. I used lots of grease.
    The small ball bearings apparently keep the shafts from bottoming out in the bushing holes.
    Replace the end cover bushing if it came with your kit. Lightly grease that bushing. Install the brushes and plate on the armature and place the plate in the end cover and secure.
    Re-install everything else in the reverse order you removed them.
    I wrote this because I could not find any information on the small ball bearing that rolled out on my work bench during disassembly or
    the gear reduction.
    It was only after finding the 2nd ball bearing that lead me to discover were the 1st one came from.
    My reverse motor rebuild works perfect. It no longer has that grinding noise it once had and the reverse speed is back to normal.
    Hope this helps someone out there. If I ever do another one, I will do the same kit seeing the wear and grit I found.
    I'm beginning to see why so many have had failure's with just replacing the brushes on these reverse motors.
    Thumbs up Reverse Motor
    Have a look at the Sticky I posted in the General and Triglide/ Freewheeler sections for more info
    80+ Posts
    Dec 2023
    New Castle, PA, USA
    Quote Originally Posted by Bouncer View Post
    the gear reduction.
    Nice Info!
    where did you get your replacement parts from?
    any links? Or just used HD parts?
    May 2021
    Milwaukee, Wi, USA
    80+ Posts
    Dec 2023
    New Castle, PA, USA
    Thanks Jeff!
    Much appreciated!
  1. Rebuilding a Rewaco RF1-GT
    By pisoiu in forum Rewaco
    Last Post: 09-23-2022, 03:20 PM
  2. Rebuilding my reverse motor today
    By Notgrownup in forum Harley Tri Glide
    Last Post: 11-29-2021, 03:14 PM
  3. rebuilding clutch master cylinder
    By OrTriker in forum Honda Trikes
    Last Post: 05-17-2021, 02:14 PM
  4. Rebuilding a Gift
    By Cleatusj in forum VW Powered Trikes
    Last Post: 05-01-2017, 08:31 PM
  5. Rebuilding Alternator
    By jackpoet in forum Honda Trikes
    Last Post: 03-31-2013, 06:33 PM
